Only 4 AT commands work on my AI-WB2-07S
Anton
Ai-WB2系列 1084 2 2023-9-4 20:45:33
I faced a problem with the AI-WB2-07S module. The module accepts only AT, AT+RST, AT+GMR, AT+RESTORE commands. The rest do not work. I don't understand what the problem is. Already used the AI AT debugger application. Directly sent commands through the terminal application.
2023-9-4 21:02:46
Hello, your question has been forwarded to the technical engineer and they will reply to you later.
  • 会员数: 31131 个
  • 话题数: 42294 篇
