啃小安派代码-4-小安派 ES8388
ckdsx.cn
小安派·S1 1372 7 2023-11-22 08:35:54
工程目录:AiPi-Open-Kits/ AiPi-Audio
文件目录:AiPi-Open-Kits/ AiPi-Audio/main.c
ES8388
该样例下载后,可以通过mic录音,喇叭播放
main 工程代码:
* @file main.c
* @brief
* Copyright (c) 2021 Bouffalolab team
* Licensed to the Apache Software Foundation (ASF) under one or more
* contributor license agreements.  See the NOTICE file distributed with
* this work for additional information regarding copyright ownership.  The
* ASF licenses this file to you under the Apache License, Version 2.0 (the
* "License"); you may not use this file except in compliance with the
* License.  You may obtain a copy of the License at
* Unless required by applicable law or agreed to in writing, software
* distributed under the License is distributed on an "AS IS" BASIS, WITHOUT
* WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.  See the
* License for the specific language governing permissions and limitations
* under the License.
*/  加载各种头文件
#include "board.h"
#include "bflb_gpio.h"
#include "bflb_l1c.h"
#include "bflb_mtimer.h"
#include "bflb_i2c.h"
#include "bl616_glb.h"
#include "bflb_dma.h"
#include "bsp_es8388.h"
#include "bflb_i2s.h"
// 8388
struct bflb_device_s *i2s0;
struct bflb_device_s *dma0_ch0;
struct bflb_device_s *dma0_ch1;
ATTR_NOCACHE_RAM_SECTION uint8_t rx_buffer[32000];    //属性缓存RAM部分
static ES8388_Cfg_Type ES8388Cfg = {    //ES8388 结构体
    .work_mode = ES8388_CODEC_MDOE,          /*!< ES8388 work mode */  //ES8388工作模式
    .role = ES8388_SLAVE,                    /*!< ES8388 role */  //ES8388角色
    .mic_input_mode = ES8388_DIFF_ENDED_MIC, /*!< ES8388 mic input mode */
    .mic_pga = ES8388_MIC_PGA_0DB,           /*!< ES8388 mic PGA */
    .i2s_frame = ES8388_LEFT_JUSTIFY_FRAME,  /*!< ES8388 I2S frame */
    .data_width = ES8388_DATA_LEN_16,        /*!< ES8388 I2S dataWitdh */
void dma0_ch0_isr(void *arg)
    printf("tc done\r\n");
void dma0_ch1_isr(void *arg)
    printf("rx done\r\n");
void i2s_gpio_init()
    struct bflb_device_s *gpio;
    /* I2S_FS */
    // bflb_gpio_init(gpio, GPIO_PIN_13, GPIO_FUNC_I2S | GPIO_ALTERNATE | GPIO_PULLUP | GPIO_SMT_EN | GPIO_DRV_1);
    // /* I2S_DI */
    // bflb_gpio_init(gpio, GPIO_PIN_14, GPIO_FUNC_I2S | GPIO_ALTERNATE | GPIO_PULLUP | GPIO_SMT_EN | GPIO_DRV_1);
    // /* I2S_DO */
    // bflb_gpio_init(gpio, GPIO_PIN_15, GPIO_FUNC_I2S | GPIO_ALTERNATE | GPIO_PULLUP | GPIO_SMT_EN | GPIO_DRV_1);
    // /* I2S_BCLK */
    // bflb_gpio_init(gpio, GPIO_PIN_20, GPIO_FUNC_I2S | GPIO_ALTERNATE | GPIO_PULLUP | GPIO_SMT_EN | GPIO_DRV_1);
    // /* MCLK CLKOUT */
    // bflb_gpio_init(gpio, GPIO_PIN_23, GPIO_FUNC_CLKOUT | GPIO_ALTERNATE | GPIO_PULLUP | GPIO_SMT_EN | GPIO_DRV_1);
    // /* I2C0_SCL */
    // bflb_gpio_init(gpio, GPIO_PIN_10, GPIO_FUNC_I2C0 | GPIO_ALTERNATE | GPIO_PULLUP | GPIO_SMT_EN | GPIO_DRV_2);
    // /* I2C0_SDA */
    // bflb_gpio_init(gpio, GPIO_PIN_11, GPIO_FUNC_I2C0 | GPIO_ALTERNATE | GPIO_PULLUP | GPIO_SMT_EN | GPIO_DRV_2);
    // bflb_gpio_init(gpio, GPIO_PIN_21, GPIO_FUNC_I2S | GPIO_ALTERNATE | GPIO_PULLUP | GPIO_SMT_EN | GPIO_DRV_1);
    /* I2S_DI */
    bflb_gpio_init(gpio, GPIO_PIN_10, GPIO_FUNC_I2S | GPIO_ALTERNATE | GPIO_PULLUP | GPIO_SMT_EN | GPIO_DRV_1);
    /* I2S_DO */
    bflb_gpio_init(gpio, GPIO_PIN_11, GPIO_FUNC_I2S | GPIO_ALTERNATE | GPIO_PULLUP | GPIO_SMT_EN | GPIO_DRV_1);
    /* I2S_BCLK */
    /* MCLK CLKOUT */
    bflb_gpio_init(gpio, GPIO_PIN_14, GPIO_FUNC_CLKOUT | GPIO_ALTERNATE | GPIO_PULLUP | GPIO_SMT_EN | GPIO_DRV_1);
    /* I2C0_SCL */
    bflb_gpio_init(gpio, GPIO_PIN_0, GPIO_FUNC_I2C0 | GPIO_ALTERNATE | GPIO_PULLUP | GPIO_SMT_EN | GPIO_DRV_2);
    /* I2C0_SDA */
    bflb_gpio_init(gpio, GPIO_PIN_1, GPIO_FUNC_I2C0 | GPIO_ALTERNATE | GPIO_PULLUP | GPIO_SMT_EN | GPIO_DRV_2);
void i2s_dma_init()   //i2s dma初始化
    static struct bflb_dma_channel_lli_pool_s tx_llipool[100];
    static struct bflb_dma_channel_lli_transfer_s tx_transfers[1];
    static struct bflb_dma_channel_lli_pool_s rx_llipool[100];
    static struct bflb_dma_channel_lli_transfer_s rx_transfers[1];
    struct bflb_i2s_config_s i2s_cfg = {  //新建结构体
        .bclk_freq_hz = 16000 * 16 * 2, /* bclk = Sampling_rate * frame_width * channel_num */
        .role = I2S_ROLE_MASTER,
        .format_mode = I2S_MODE_LEFT_JUSTIFIED,
        .channel_mode = I2S_CHANNEL_MODE_NUM_2,
        .frame_width = I2S_SLOT_WIDTH_16,
        .data_width = I2S_SLOT_WIDTH_16,
        .fs_offset_cycle = 0,
        .tx_fifo_threshold = 0,
        .rx_fifo_threshold = 0,
    struct bflb_dma_channel_config_s tx_config = {  //flb dma信道配置tx配置
        .direction = DMA_MEMORY_TO_PERIPH,
        .src_req = DMA_REQUEST_NONE,
        .dst_req = DMA_REQUEST_I2S_TX,
        .src_addr_inc = DMA_ADDR_INCREMENT_ENABLE,
        .dst_addr_inc = DMA_ADDR_INCREMENT_DISABLE,
        .src_burst_count = DMA_BURST_INCR1,
        .dst_burst_count = DMA_BURST_INCR1,
        .src_width = DMA_DATA_WIDTH_16BIT,
        .dst_width = DMA_DATA_WIDTH_16BIT,
    struct bflb_dma_channel_config_s rx_config = {  //flb dma信道配置rx配置
        .direction = DMA_PERIPH_TO_MEMORY,
        .src_req = DMA_REQUEST_I2S_RX,
        .dst_req = DMA_REQUEST_NONE,
        .src_addr_inc = DMA_ADDR_INCREMENT_DISABLE,
        .dst_addr_inc = DMA_ADDR_INCREMENT_ENABLE,
    printf("i2s init\r\n");
    i2s0 = bflb_device_get_by_name("i2s0");
    /* i2s init */   //初始化i2s
    bflb_i2s_init(i2s0, &i2s_cfg);
    /* enable dma */  //启动 dma
    bflb_i2s_link_txdma(i2s0, true);
    bflb_i2s_link_rxdma(i2s0, true);
    printf("dma init\r\n");
    dma0_ch0 = bflb_device_get_by_name("dma0_ch0");
    dma0_ch1 = bflb_device_get_by_name("dma0_ch1");
    bflb_dma_channel_init(dma0_ch0, &tx_config);
    bflb_dma_channel_init(dma0_ch1, &rx_config);
    bflb_dma_channel_irq_attach(dma0_ch0, dma0_ch0_isr, NULL);
    bflb_dma_channel_irq_attach(dma0_ch1, dma0_ch1_isr, NULL);
    tx_transfers[0].src_addr = (uint32_t)rx_buffer;
    tx_transfers[0].dst_addr = (uint32_t)DMA_ADDR_I2S_TDR;
    tx_transfers[0].nbytes = sizeof(rx_buffer);
    rx_transfers[0].src_addr = (uint32_t)DMA_ADDR_I2S_RDR;
    rx_transfers[0].dst_addr = (uint32_t)rx_buffer;
    rx_transfers[0].nbytes = sizeof(rx_buffer);
    printf("dma lli init\r\n");
    uint32_t num = bflb_dma_channel_lli_reload(dma0_ch0, tx_llipool, 100, tx_transfers, 1);
    bflb_dma_channel_lli_link_head(dma0_ch0, tx_llipool, num);
    printf("tx dma lli num: %d \r\n", num);
    num = bflb_dma_channel_lli_reload(dma0_ch1, rx_llipool, 100, rx_transfers, 1);
    printf("rx dma lli num: %d \r\n", num);
    bflb_dma_channel_lli_link_head(dma0_ch1, rx_llipool, num);
    bflb_dma_channel_start(dma0_ch0);
    bflb_dma_channel_start(dma0_ch1);
void mclk_out_init()   //输出时钟初始化
    /* output MCLK,
    Will change the clock source of i2s, //将改变i2s的时钟源,
    It needs to be called before i2s is initialized  //在初始化i2s之前需要调用它
    clock source 25M //时钟源25M
    GLB_Set_I2S_CLK(ENABLE, 2, GLB_I2S_DI_SEL_I2S_DI_INPUT, GLB_I2S_DO_SEL_I2S_DO_OUTPT);
    // GLB_Set_Chip_Clock_Out3_Sel(GLB_CHIP_CLK_OUT_3_I2S_REF_CLK);
    GLB_Set_Chip_Clock_Out2_Sel(GLB_CHIP_CLK_OUT_2_I2S_REF_CLK);
int main(void)  //主函数
    board_init(); //开发板初始化
    printf("lvgl case\r\n");   //lvgl 示例
    /* gpio init */
    i2s_gpio_init();   //gpio初始化
    /* mclk clkout init */
    mclk_out_init();   //输出时钟初始化
    /* init ES8388 Codec */
    printf("es8388 init\n\r");
    ES8388_Init(&ES8388Cfg); //初始化
    ES8388_Set_Voice_Volume(90);  //设置音量
    /* i2s init */
    i2s_dma_init();  //初始化
    /* enable i2s tx and rx */  //启动I2s 的输入 输出
    bflb_i2s_feature_control(i2s0, I2S_CMD_DATA_ENABLE, I2S_CMD_DATA_ENABLE_TX | I2S_CMD_DATA_ENABLE_RX);
    while (1) {  //无限循环
        bflb_mtimer_delay_ms(1);  //延时1毫秒函数
除了排版以外,其他的都非常棒
2023-11-25 21:01:33
2023-11-26 23:08:35
2023-11-29 09:08:38
打卡
2024-4-23 16:38:04
真的棒啊
  • 会员数: 31143 个
  • 话题数: 42220 篇
