请
后使用快捷导航
没有账号?
Ai-M61系列
【Ai-M61-32s-kit】开发板烧录程序发生错误 ...
码录编
金牌会员, 积分 1078, 距离下一级还需 1922 积分
2人留言
楼主
Ai-M61系列
1473
2023-11-20 17:03:11
[i=s] 本帖最后由 码录编 于 2023-11-20 17:03 编辑 [/i]
> 本帖最后由 码录编 于 2023-11-20 16:23 编辑 # 一、尝试烧录examples\helloworld文件 我尝试着烧录编文件,输入命令:make flash COMX=COM3 如下图所示: ```powershell PS C:\Install\Study\AiPi-Open-Kits\aithinker_Ai-M6X_SDK\examples\helloworld> make flash COMX=COM3 ./../../tools/cmake/bin/cmake.exe -S . -B build -G "MinGW Makefiles" -DCROSS_COMPILE=riscv64-unknown-elf- -DCHIP=bl616 -DCPU_ID= -DBOARD=bl616dk -DBOARD_DIR= -DCONFIG_DEBUG=y -DCONFIG_ROMAPI=y -DCONFIG_USB_HS=y -DCONFIG_COMX=COM3 -DCMAKE_EXPORT_COMPILE_COMMANDS=OFF -DCONFIG_TLSF=y -- [register library : libc], path:C:/Install/Study/AiPi-Open-Kits/aithinker_Ai-M6X_SDK/components/libc -- [register library : mm], path:C:/Install/Study/AiPi-Open-Kits/aithinker_Ai-M6X_SDK/components/mm -- [register library : utils], path:C:/Install/Study/AiPi-Open-Kits/aithinker_Ai-M6X_SDK/components/utils -- [register library : lhal], path:C:/Install/Study/AiPi-Open-Kits/aithinker_Ai-M6X_SDK/drivers/lhal -- [register extern library : libcsi_xt900p32f_dsp], path:C:/Install/Study/AiPi-Open-Kits/aithinker_Ai-M6X_SDK/drivers/lhal -- [register extern library : libpka], path:C:/Install/Study/AiPi-Open-Kits/aithinker_Ai-M6X_SDK/drivers/lhal -- [register library : std], path:C:/Install/Study/AiPi-Open-Kits/aithinker_Ai-M6X_SDK/drivers/soc/bl616/std -- Configuring done -- Generating done -- Build files have been written to: C:/Install/Study/AiPi-Open-Kits/aithinker_Ai-M6X_SDK/examples/helloworld/build make -C build -j8 [ 2%] Built target app [ 7%] Built target utils [ 10%] Built target mm [ 24%] Built target std [ 89%] Built target lhal [ 98%] Built target libc [100%] Built target helloworld_bl616.elf make -C build combine [13:58:31.617] - bflb firmware post process : V1.2.0 [13:58:31.617] - Chipname: bl616 [13:58:31.617] - Board config dir: ./../../bsp/board/bl616dk/config [13:58:31.617] - Create partition using partition_cfg_4M.toml [13:58:31.617] - Create dts for C:\Install\Study\AiPi-Open-Kits\aithinker_Ai-M6X_SDK\examples\helloworld\build\build_out\helloworld_bl616.bin [13:58:31.617] - Create dts using bl_factory_params_IoTKitA_auto.dts [13:58:31.634] - 4K header found,append dts file [13:58:31.635] - Copy boot2_bl616_release_v8.0.8.bin [13:58:31.636] - Copy mfg_bl616_gu_af8b0946f_v2.26.bin [13:58:31.640] - Create dts for C:\Install\Study\AiPi-Open-Kits\aithinker_Ai-M6X_SDK\examples\helloworld\build\build_out\mfg_bl616_gu_af8b0946f_v2.26.bin [13:58:31.640] - Create dts using bl_factory_params_IoTKitA_auto.dts [13:58:31.650] - 4K header found,append dts file [13:58:31.650] - Process C:\Install\Study\AiPi-Open-Kits\aithinker_Ai-M6X_SDK\examples\helloworld\build\build_out\helloworld_bl616.bin [13:58:31.651] - ========= sp image create ========= [13:58:31.652] - Flash config crc: b'b5fec518' [13:58:31.652] - Clock config crc: b'4a05f490' [13:58:31.653] - Image Offset:0x1000 [13:58:31.653] - Image hash is b'f6396d515e7b6b516fdd39c705d34fd83d85d7191471ce279f651488d1279ef8' [13:58:31.654] - Encrypt efuse data [13:58:31.658] - Image Offset:0x1000 [13:58:31.659] - Image hash ignore,not calculate [13:58:31.660] - Bootheader config crc: b'4ddfb44c' [13:58:31.661] - Process C:\Install\Study\AiPi-Open-Kits\aithinker_Ai-M6X_SDK\examples\helloworld\build\build_out\boot2_bl616_release_v8.0.8.bin [13:58:31.662] - ========= sp image create ========= [13:58:31.662] - Flash config crc: b'b5fec518' [13:58:31.663] - Clock config crc: b'4a05f490' [13:58:31.663] - Image Offset:0x2000 [13:58:31.663] - Image hash is b'4f4eecaddc6e597708f626253879f5560534d2e3baff848f4d96fabbce4b020f' [13:58:31.664] - Encrypt efuse data [13:58:31.666] - Image Offset:0x2000 [13:58:31.666] - Image hash ignore,not calculate [13:58:31.666] - Bootheader config crc: b'ccbfa125' [13:58:31.667] - Process C:\Install\Study\AiPi-Open-Kits\aithinker_Ai-M6X_SDK\examples\helloworld\build\build_out\mfg_bl616_gu_af8b0946f_v2.26.bin [13:58:31.668] - ========= sp image create ========= [13:58:31.669] - Flash config crc: b'4fb1fe70' [13:58:31.669] - Clock config crc: b'0b34ef89' [13:58:31.670] - Image Offset:0x1000 [13:58:31.674] - Image hash is b'69de5b7af45fea2e456fb6864612126bbdad58e69294d1466a2f892e010d1f3d' [13:58:31.675] - Encrypt efuse data [13:58:31.677] - Image Offset:0x1000 [13:58:31.678] - Bootheader config crc: b'f9cf01e0' [13:58:31.679] - create OTA file:C:\Install\Study\AiPi-Open-Kits\aithinker_Ai-M6X_SDK\examples\helloworld\build\build_out\helloworld_bl616.bin.ota [13:58:31.690] - create XZ file:C:\Install\Study\AiPi-Open-Kits\aithinker_Ai-M6X_SDK\examples\helloworld\build\build_out\helloworld_bl616.xz[13:58:31.717] - create XZ OTA file:C:\Install\Study\AiPi-Open-Kits\aithinker_Ai-M6X_SDK\examples\helloworld\build\build_out\helloworld_bl616.xz.ota Built target combine ./../../tools/bflb_tools/bouffalo_flash_cube/BLFlashCommand.exe --interface=uart --baudrate=2000000 --port=COM3 --chipname=bl616 --cpu_id= --config=flash_prog_cfg.ini ['./../../tools/bflb_tools/bouffalo_flash_cube/BLFlashCommand.exe', '--interface=uart', '--baudrate=2000000', '--port=COM3', '--chipname=bl616', '--cpu_id=', '--config=flash_prog_cfg.ini'] [13:58:33.922] - Serial port is COM3 [13:58:33.922] - ================================================== [13:58:33.940] - Program Start [13:58:33.940] - ========= eflash loader cmd arguments ========= [13:58:33.942] - serial port is COM3 [13:58:33.942] - chiptype: bl616 [13:58:33.943] - cpu_reset=False [13:58:33.966] - ========= Interface is uart ========= [13:58:33.967] - Bootrom load [13:58:33.967] - ========= get_boot_info ========= [13:58:33.967] - ========= image get bootinfo ========= [13:58:34.242] - tx rx and power off, press the machine! [13:58:34.242] - cutoff time is 0.05 [13:58:34.301] - power on tx and rx [13:58:35.303] - reset cnt: 0, reset hold: 0.05, shake hand delay: 0.1 [13:58:35.303] - clean buf [13:58:35.304] - send sync [13:58:35.550] - ack is b'0080000000000000000000000000000000000000000000f8f80000f8f800000000f800f800f800f800f80000000000f800f800f800000000000000000000000000f8f80000000000f80000000000f800000000000000000000f800f8f8f8000000f800f80078f88000000080000000f8f8f8f800000000000000008000f878000000000000f800f800f8f80000f800f8000000f8f87800f8800000f800f80000000000f8f80000f8f800f8000000f800f8000000f800f800000000f8f8f8f800f8f8000000f800f800f800f800f80000000000f80000000000000000f80000f80000000000000000008000f800f8f80000f8000000f8000000008000000080f8007800f8f800f8000000f800f8000000f80000000000000000f800f8f8f8000000f8f88000f8000000f8f8000000000000f800000000780000000000f800f800f800f800f8f800000000f8f88000f800f80000f80000f80000000000f8f8f8800000f800f8f800f8007800f800f8f800f800f80000f8f800f8f800f800f80000f8f800000000f8f8f80000f800f8000000f80000f800f8000000f800000000f8f80000f8f800000000f8f8f8f8f8f8f8f800f800000000f878f8000000000000000000000000f80000f800f800f80000f80000000000f800f800f8f880f800000000f8f800f80000000000f800f800f8000000f87800f80000f80000f80000f8f80000f8f878f8000000f8000000008000000080000000f8800000008000000000f800f800f800f8000000f800f8000000f8f80000f8f8000000f8f80000f8f8000000f8000000f8f8f80000f8' [13:58:35.551] - reshake [13:58:35.819] - tx rx and power off, press the machine! [13:58:35.819] - cutoff time is 0.05 [13:58:35.883] - power on tx and rx [13:58:36.904] - reset cnt: 0, reset hold: 0.05, shake hand delay: 0.1 [13:58:36.904] - clean buf [13:58:36.904] - send sync [13:58:37.036] - ack is b'' [13:58:37.036] - retry [13:58:37.312] - tx rx and power off, press the machine! [13:58:37.312] - cutoff time is 0.05 [13:58:37.376] - power on tx and rx [13:58:38.366] - reset cnt: 0, reset hold: 0.05, shake hand delay: 0.1 [13:58:38.366] - clean buf [13:58:38.366] - send sync [13:58:38.504] - ack is b'' [13:58:38.504] - retry [13:58:38.504] - shake hand fail [13:58:38.504] - ######################################################################## [13:58:38.504] - Boot pin是否上拉到板子自身的3.3V,而不是外部的3.3V [13:58:38.504] - UART RX是否连接到USB转串口的TX引脚 [13:58:38.504] - UART TX是否连接到USB转串口的RX引脚 [13:58:38.504] - 在使用烧录软件进行烧录前,是否在Boot pin拉高的情况下,使用Reset/Chip_En复位了芯片 [13:58:38.504] - 烧录软件所选择的COM口,是否是连接芯片的串口 [13:58:38.504] - 烧录软件上选择的波特率是否是USB转串口支持的波特率 [13:58:38.504] - 3.3V供电是否正常 [13:58:38.504] - 板子供电电流是否正常(烧录模式下,芯片耗电电流5-7mA) [13:58:38.504] - ######################################################################## [13:58:38.504] - shake hand fail [13:58:38.504] - ========= ChipID: ========= [13:58:38.504] - Get bootinfo time cost(ms): 4536.875732421875 [13:58:38.504] - {"ErrorCode": "0050","ErrorMsg":"BFLB IMG LOAD SHAKEHAND FAIL"} [13:58:38.504] - Burn Retry [13:58:38.504] - Burn return with retry fail ``` 运行后发生了错误,我尝试着分析原因以及解决办法。 # 二、查询原因 我是纯新手小白,没有使用过开发板。 我先去安信可论坛搜索“Ai-M1-32s-kit 烧录失败”,结果发现没有😕 ,也许只有我会在这一步发生错误吧!😄 ## 2.1、自己捣鼓捣鼓 命令是否敲错?👍 端口号对不对啊?👍 板子是好的吗?👍 ## 2.2、在论坛中寻求答案 但是我参考了这篇帖子:[【小安基于Ai-M61-32s [BL616] 串口通讯】]([http://bbs.ai-thinker.com/forum.php?mod=viewthread&tid=41814&extra=page%3D1&_dsign=d02a6f91](http://bbs.ai-thinker.com/forum.php?mod=viewthread&tid=41814&extra=page%3D1&_dsign=d02a6f91) "点击快速访问"),大家可以点进去看一下这篇帖子,写的很不错,我相信对大家来说是有帮助的,特别是新手。 ## 2.3、在文档中寻求帮助 【小安基于Ai-M61-32s [BL616] 串口通讯】里面给了一个链接:[博流SDK文档链接]([https://bl-mcu-sdk.readthedocs.io/zh_CN/latest/](https://bl-mcu-sdk.readthedocs.io/zh_CN/latest/) "点击快速访问"),在“快速入门-环境搭建-烧录”中提到: 1. BouffaloSDK 烧录代码提供两种:命令行和界面。需要注意,如果使用第三方 usb转串口模块,部分不支持 2M 波特率烧录,例如 CH340,请降低波特率使用(小于500K); 2. 在烧录之前需要保证芯片进入烧录模式:按住 boot 键,按下 reset 键,松开 reset 键,松开 boot,即可进入烧录模式。 **还真是巧了,这也许就是我的解决之道啊!😄** # 三、尝试解决问题 ## 3.1、根据文档我们获得了两个可能造成烧录失败的原因: > 1、波特率; > > 2、芯片是否进入烧录模式; > > ## 3.2、开发板按键说明:  ## 3.3、尝试着再次烧录 这次我修改了波特率为115200,并且按照“按住烧录按键-->回车执行命令-->按住复位按键-->停留1秒-->松开复位按键-->松开烧录按键”的顺序进行烧录。 ```powershell PS C:\Install\Study\AiPi-Open-Kits\aithinker_Ai-M6X_SDK\examples\helloworld> make flash CHIP=bl616 COMX=COM3 baudrate=115200 ./../../tools/cmake/bin/cmake.exe -S . -B build -G "MinGW Makefiles" -DCROSS_COMPILE=riscv64-unknown-elf- -DCHIP=bl616 -DCPU_ID= -DBOARD=bl616dk -DBOARD_DIR= -DCONFIG_DEBUG=y -DCONFIG_ROMAPI=y -DCONFIG_USB_HS=y -DCONFIG_COMX=COM3 -DCMAKE_EXPORT_COMPILE_COMMANDS=OFF -DCONFIG_TLSF=y -- [register library : libc], path:C:/Install/Study/AiPi-Open-Kits/aithinker_Ai-M6X_SDK/components/libc -- [register library : mm], path:C:/Install/Study/AiPi-Open-Kits/aithinker_Ai-M6X_SDK/components/mm -- [register library : utils], path:C:/Install/Study/AiPi-Open-Kits/aithinker_Ai-M6X_SDK/components/utils -- [register library : lhal], path:C:/Install/Study/AiPi-Open-Kits/aithinker_Ai-M6X_SDK/drivers/lhal -- [register extern library : libcsi_xt900p32f_dsp], path:C:/Install/Study/AiPi-Open-Kits/aithinker_Ai-M6X_SDK/drivers/lhal -- [register extern library : libpka], path:C:/Install/Study/AiPi-Open-Kits/aithinker_Ai-M6X_SDK/drivers/lhal -- [register library : std], path:C:/Install/Study/AiPi-Open-Kits/aithinker_Ai-M6X_SDK/drivers/soc/bl616/std -- Configuring done -- Generating done CMake Warning: Manually-specified variables were not used by the project: CONFIG_COMX -- Build files have been written to: C:/Install/Study/AiPi-Open-Kits/aithinker_Ai-M6X_SDK/examples/helloworld/build make -C build -j8 [ 2%] Built target app [ 7%] Built target utils [ 10%] Built target mm [ 39%] Built target std [ 76%] Built target libc [ 98%] Built target lhal [100%] Built target helloworld_bl616.elf make -C build combine [14:53:43.160] - bflb firmware post process : V1.2.0 [14:53:43.160] - Chipname: bl616 [14:53:43.160] - Board config dir: ./../../bsp/board/bl616dk/config [14:53:43.160] - Create partition using partition_cfg_4M.toml [14:53:43.165] - Create dts for C:\Install\Study\AiPi-Open-Kits\aithinker_Ai-M6X_SDK\examples\helloworld\build\build_out\helloworld_bl616.bin [14:53:43.166] - Create dts using bl_factory_params_IoTKitA_auto.dts [14:53:43.172] - 4K header found,append dts file [14:53:43.173] - Copy boot2_bl616_release_v8.0.8.bin [14:53:43.174] - Copy mfg_bl616_gu_af8b0946f_v2.26.bin [14:53:43.177] - Create dts for C:\Install\Study\AiPi-Open-Kits\aithinker_Ai-M6X_SDK\examples\helloworld\build\build_out\mfg_bl616_gu_af8b0946f_v2.26.bin [14:53:43.177] - Create dts using bl_factory_params_IoTKitA_auto.dts [14:53:43.186] - 4K header found,append dts file [14:53:43.188] - Process C:\Install\Study\AiPi-Open-Kits\aithinker_Ai-M6X_SDK\examples\helloworld\build\build_out\helloworld_bl616.bin [14:53:43.189] - ========= sp image create ========= [14:53:43.189] - Flash config crc: b'b5fec518' [14:53:43.189] - Clock config crc: b'4a05f490' [14:53:43.189] - Image Offset:0x1000 [14:53:43.190] - Image hash is b'f6396d515e7b6b516fdd39c705d34fd83d85d7191471ce279f651488d1279ef8' [14:53:43.190] - Encrypt efuse data [14:53:43.195] - Image Offset:0x1000 [14:53:43.195] - Image hash ignore,not calculate [14:53:43.195] - Bootheader config crc: b'4ddfb44c' [14:53:43.196] - Process C:\Install\Study\AiPi-Open-Kits\aithinker_Ai-M6X_SDK\examples\helloworld\build\build_out\boot2_bl616_release_v8.0.8.bin [14:53:43.197] - ========= sp image create ========= [14:53:43.197] - Flash config crc: b'b5fec518' [14:53:43.198] - Clock config crc: b'4a05f490' [14:53:43.198] - Image Offset:0x2000 [14:53:43.199] - Image hash is b'4f4eecaddc6e597708f626253879f5560534d2e3baff848f4d96fabbce4b020f' [14:53:43.199] - Encrypt efuse data [14:53:43.201] - Image Offset:0x2000 [14:53:43.202] - Image hash ignore,not calculate [14:53:43.202] - Bootheader config crc: b'ccbfa125' [14:53:43.203] - Process C:\Install\Study\AiPi-Open-Kits\aithinker_Ai-M6X_SDK\examples\helloworld\build\build_out\mfg_bl616_gu_af8b0946f_v2.26.bin [14:53:43.204] - ========= sp image create ========= [14:53:43.205] - Flash config crc: b'4fb1fe70' [14:53:43.205] - Clock config crc: b'0b34ef89' [14:53:43.205] - Image Offset:0x1000 [14:53:43.210] - Image hash is b'69de5b7af45fea2e456fb6864612126bbdad58e69294d1466a2f892e010d1f3d' [14:53:43.211] - Encrypt efuse data [14:53:43.213] - Image Offset:0x1000 [14:53:43.213] - Bootheader config crc: b'f9cf01e0' [14:53:43.214] - create OTA file:C:\Install\Study\AiPi-Open-Kits\aithinker_Ai-M6X_SDK\examples\helloworld\build\build_out\helloworld_bl616.bin.ota [14:53:43.223] - create XZ file:C:\Install\Study\AiPi-Open-Kits\aithinker_Ai-M6X_SDK\examples\helloworld\build\build_out\helloworld_bl616.xz[14:53:43.249] - create XZ OTA file:C:\Install\Study\AiPi-Open-Kits\aithinker_Ai-M6X_SDK\examples\helloworld\build\build_out\helloworld_bl616.xz.ota Built target combine ./../../tools/bflb_tools/bouffalo_flash_cube/BLFlashCommand.exe --interface=uart --baudrate=2000000 --port=COM3 --chipname=bl616 --cpu_id= --config=flash_prog_cfg.ini ['./../../tools/bflb_tools/bouffalo_flash_cube/BLFlashCommand.exe', '--interface=uart', '--baudrate=2000000', '--port=COM3', '--chipname=bl616', '--cpu_id=', '--config=flash_prog_cfg.ini'] [14:53:45.511] - Serial port is COM3 [14:53:45.511] - ================================================== [14:53:45.522] - Program Start [14:53:45.522] - ========= eflash loader cmd arguments ========= [14:53:45.524] - serial port is COM3 [14:53:45.524] - chiptype: bl616 [14:53:45.524] - cpu_reset=False [14:53:45.554] - ========= Interface is uart ========= [14:53:45.554] - Bootrom load [14:53:45.554] - ========= get_boot_info ========= [14:53:45.555] - ========= image get bootinfo ========= [14:53:45.838] - tx rx and power off, press the machine! [14:53:45.838] - cutoff time is 0.05 [14:53:45.897] - power on tx and rx [14:53:46.885] - reset cnt: 0, reset hold: 0.05, shake hand delay: 0.1 [14:53:46.885] - clean buf [14:53:46.886] - send sync [14:53:47.129] - ack is b'4f4b464c0201' [14:53:47.165] - shake hand success [14:53:47.676] - data read is b'01001606000001002712890127fc2acf0eb496000f758010' [14:53:47.676] - ========= ChipID: b40ecf2afc27 ========= [14:53:47.676] - Get bootinfo time cost(ms): 2121.32861328125 [14:53:47.676] - change bdrate: 2000000 [14:53:47.676] - Clock PLL set [14:53:47.676] - Set clock time cost(ms): 0.0 [14:53:47.799] - Read mac addr [14:53:47.799] - flash set para [14:53:47.799] - get flash pin cfg from bootinfo: 0x24 [14:53:47.799] - set flash cfg: 14124 [14:53:47.799] - Set flash config [14:53:47.799] - Set para time cost(ms): 0.0 [14:53:47.799] - ========= flash read jedec ID ========= [14:53:47.807] - Read flash jedec ID [14:53:47.807] - readdata: [14:53:47.807] - b'5e401700' [14:53:47.807] - Finished [14:53:47.820] - Program operation [14:53:47.821] - Dealing Index 0 [14:53:47.821] - ========= programming C:\Install\Study\AiPi-Open-Kits\aithinker_Ai-M6X_SDK\examples\helloworld\.\build\build_out\helloworld_bl616.bin to 0x000000 [14:53:47.830] - flash para file: C:\Install\Study\AiPi-Open-Kits\aithinker_Ai-M6X_SDK\tools\bflb_tools\bouffalo_flash_cube\chips/bl616/efuse_bootheader/flash_para.bin [14:53:47.832] - Set flash config [14:53:47.836] - Set para time cost(ms): 3.99560546875 [14:53:47.836] - ========= flash load ========= [14:53:47.837] - ========= flash erase ========= [14:53:47.837] - Erase flash from 0x0 to 0x97bf [14:53:48.141] - Erase time cost(ms): 303.5146484375 [14:53:48.166] - Load 2048/38848 {"progress":5} [14:53:48.182] - Load 4096/38848 {"progress":10} [14:53:48.197] - Load 6144/38848 {"progress":15} [14:53:48.213] - Load 8192/38848 {"progress":21} [14:53:48.228] - Load 10240/38848 {"progress":26} [14:53:48.244] - Load 12288/38848 {"progress":31} [14:53:48.259] - Load 14336/38848 {"progress":36} [14:53:48.275] - Load 16384/38848 {"progress":42} [14:53:48.290] - Load 18432/38848 {"progress":47} [14:53:48.306] - Load 20480/38848 {"progress":52} [14:53:48.321] - Load 22528/38848 {"progress":57} [14:53:48.337] - Load 24576/38848 {"progress":63} [14:53:48.353] - Load 26624/38848 {"progress":68} [14:53:48.368] - Load 28672/38848 {"progress":73} [14:53:48.384] - Load 30720/38848 {"progress":79} [14:53:48.399] - Load 32768/38848 {"progress":84} [14:53:48.415] - Load 34816/38848 {"progress":89} [14:53:48.430] - Load 36864/38848 {"progress":94} [14:53:48.445] - Load 38848/38848 {"progress":100} [14:53:48.446] - Load 38848/38848 {"progress":100} [14:53:48.446] - Write check [14:53:48.450] - Flash load time cost(ms): 309.282470703125 [14:53:48.451] - Finished [14:53:48.452] - Sha caled by host: ef9d99f663868c635a791d659fab6158684b16148f72046b5902d684601247a2 [14:53:48.452] - xip mode Verify [14:53:48.488] - Read Sha256/38848 [14:53:48.488] - Flash xip readsha time cost(ms): 33.9794921875 [14:53:48.488] - Finished [14:53:48.490] - Sha caled by dev: ef9d99f663868c635a791d659fab6158684b16148f72046b5902d684601247a2 [14:53:48.490] - Verify success [14:53:48.491] - Program Finished [14:53:48.491] - All time cost(ms): 2969.503173828125 [14:53:48.598] - close interface [14:53:48.598] - [All Success] ``` 毫无疑问他成功了!!!🎉️ 🎉️ 🎉️ 但是我当时还没发判断是这两个原因中的哪一个导致烧录失败的。 直到后来我返回来看第99行,其实可以发现串口通讯采用的波特率依然是2000000,并没有修改成功。 在此次烧录成功后,我又一次尝试烧录,并将波特率修改为2000000,只是改变了按键的按下以及松开的顺序。 # 四、我获得了什么 1. 遇事莫慌张! 2. 先自己想办法解决,实在是没有办法就寻求外在的帮助。 3. 多看文档,其实文档里面有解决办法,只是没有发现罢了。 4. 多发帖,做总结!
烧录错误
Ai-M61-32S
相关帖子
安信可Ai-M61-32SU PWM 点 RGB
【祖传点灯】安信可Ai-M61-32S 点灯
【祖传点灯】安信可Ai-M61-32S 运行实例
【祖传点灯】安信可Ai-M61-32S
【祖传点灯】安信可Ai-M61-32S + 初次点灯
【祖传点灯】安信可Ai-M61-32S
【祖传点灯】安信可Ai-M61-32S + 点灯,交作业
【祖传点灯】安信可Ai-M61-32S + Clion环境配置 + 点自己的灯
AI_M61-32S核心板
【求助贴】SDK更新后如何搭建开发环境
2 回复
电梯直达
正序浏览
倒序浏览
正序浏览
沙发
2023-11-20 17:23:22
优秀~
板凳
码录编
楼主
2023-11-20 17:29:04
其实在我们下载下来的SDK中已经有烧录参考文档:
\AiPi-Open-Kits\aithinker_Ai-M6X_SDK\tools\bflb_tools\bouffalo_flash_cube\docs
BW20-12F-KIT usbd_inic_dplus问题
BU04 原理图
[WB2] 实现自动发现局域网下的设备
星闪连接个数
小安派-Eyes-S1 - GPIO中断编程
智能环境监测系统可行性猜想
论坛应该出一个发帖时间排序
BU04 原理图
小安派-Eyes-S1 - UART
会员数: 30550 个
话题数: 44705 篇
