【BW21-CBV-Kit 开发套件测评】OLED 显示
无垠的广袤
小安派·BW21-CBV-KIt 28 1 昨天 23:02
本文介绍了安信可 BW21-CBV-Kit 开发套件实现 OLED 屏幕显示的相关测试。
IIC 设备扫描
这里介绍了 IIC 设备扫描的代码和实现流程。
硬件连接
OLED_SCL -> 12
OLED_SDA -> 13
示意图
代码
打开例程 Examples - AmebaWire - I2CScanner
// i2c_scanner
// This sketch tests the standard 7-bit addresses
// Devices with higher bit address might not be seen properly.
 Example guide:
 https://www.amebaiot.com/en/amebapro2-arduino-i2c-scan/
#include <Wire.h>
void setup()
    Wire.begin();
    Serial.begin(115200);
    while (!Serial)
        ;    // wait for serial monitor
    Serial.println("\nI2C Scanner");
void loop()
    byte error, address;
    byte x = 0;
    int nDevices;
    Serial.println("Scanning...");
    nDevices = 0;
    for (address = 0; address < 127; address++) {
        // The i2c_scanner uses the return value of
        // the Write.endTransmisstion to see if
        // a device did acknowledge to the address.
        Wire.beginTransmission(address);
        Wire.write(x);
        error = Wire.endTransmission();
        if (error == 0) {
            Serial.print("I2C device found at address 0x");
            if (address < 16) {
                Serial.print("0");
            Serial.print(address, HEX);
            Serial.println("  !");
            nDevices++;
        } else if (error == 4) {
            Serial.print("Unknown error at address 0x");
            if (address < 16) {
                Serial.print("0");
            Serial.println(address, HEX);
    if (nDevices == 0) {
        Serial.println("No I2C devices found\n");
    } else {
        Serial.println("done\n");
    delay(5000);    // wait 2 seconds for next scan
按照示意图连接硬件,编译并上传固件,复位后运行程序;
打开串口监视器,每秒打印一次 IIC 设备扫描结果。
效果
串口输出连接的 IIC 设备地址
SSD1306显示
在前面关于 IIC 设备扫描的基础上,结合例程 Examples - AmebaWire - OLED_SSD1306 ,通过 IIC 通信协议驱动基于 SSD1306 驱动器的 OLED 设备,实现图片和文字显示。
代码
参考例程 Examples - AmebaWire - OLED_SSD1306 ,截取图片动态散落的部分。
#include <Wire.h>
#include <Adafruit_OLED_libraries/Adafruit_GFX.h>
#include <Adafruit_OLED_libraries/Adafruit_SSD1306.h>
#define SCREEN_WIDTH  128    // OLED display width, in pixels
#define SCREEN_HEIGHT 64     // OLED display height, in pixels
// Declaration for an SSD1306 display connected to I2C (SDA, SCL pins)
// The pins for I2C are defined by the Wire-library.
#define OLED_RESET     -1      // Reset pin # (or -1 if sharing Arduino reset pin)
#define SCREEN_ADDRESS 0x3C    ///< See datasheet for Address
Adafruit_SSD1306 display(SCREEN_WIDTH, SCREEN_HEIGHT, &Wire, OLED_RESET);
#define NUMFLAKES 10    // Number of snowflakes in the animation example
#define LOGO_HEIGHT_FLAKES 16
#define LOGO_WIDTH_FLAKES  16
static const unsigned char PROGMEM logo_bmp_flake[] =
    {0b00000000, 0b11000000,
     0b00000001, 0b11000000,
     0b00000011, 0b11100000,
     0b11110011, 0b11100000,
     0b11111110, 0b11111000,
     0b01111110, 0b11111111,
     0b00110011, 0b10011111,
     0b00011111, 0b11111100,
     0b00001101, 0b01110000,
     0b00011011, 0b10100000,
     0b00111111, 0b11100000,
     0b00111111, 0b11110000,
     0b01111100, 0b11110000,
     0b01110000, 0b01110000,
     0b00000000, 0b00110000};
void setup()
    // SSD1306_SWITCHCAPVCC = generate display voltage from 3.3V internally
    if (!display.begin(SSD1306_SWITCHCAPVCC, SCREEN_ADDRESS)) {
        Serial.println(F("SSD1306 allocation failed"));
        for (;;)
            ;    // Don't proceed, loop forever
    // Clear the buffer
    display.clearDisplay();
    // Show the display buffer on the screen. You MUST call display() after
    // drawing commands to make them visible on screen!
    display.display();
    delay(500);
    testanimate(logo_bmp_flake, LOGO_WIDTH_FLAKES, LOGO_HEIGHT_FLAKES);    // Animate bitmaps
void loop()
#define XPOS   0    // Indexes into the 'icons' array in function below
#define YPOS   1
#define DELTAY 2
void testanimate(const uint8_t *bitmap, uint8_t w, uint8_t h)
    int8_t f, icons[NUMFLAKES][3];
    // Initialize 'snowflake' positions
    for (f = 0; f < NUMFLAKES; f++) {
        icons[f][XPOS] = random(1 - LOGO_WIDTH_FLAKES, display.width());
        icons[f][YPOS] = -LOGO_HEIGHT_FLAKES;
        icons[f][DELTAY] = random(1, 6);
        Serial.print(F("x: "));
        Serial.print(icons[f][XPOS], DEC);
        Serial.print(F(" y: "));
        Serial.print(icons[f][YPOS], DEC);
        Serial.print(F(" dy: "));
        Serial.println(icons[f][DELTAY], DEC);
    for (;;) {                     // Loop forever...
        display.clearDisplay();    // Clear the display buffer
        // Draw each snowflake:
            display.drawBitmap(icons[f][XPOS], icons[f][YPOS], bitmap, w, h, SSD1306_WHITE);
        display.display();    // Show the display buffer on the screen
        delay(200);           // Pause for 1/10 second
        // Then update coordinates of each flake...
            icons[f][YPOS] += icons[f][DELTAY];
            // If snowflake is off the bottom of the screen...
            if (icons[f][YPOS] >= display.height()) {
                // Reinitialize to a random position, just off the top
编译并上传固件,实现花朵随机下落的效果。
OLED 取模网站:image2cpp .
效果
散落的星星
总结
本文介绍了安信可 BW21-CBV-Kit 开发套件实现 OLED 屏幕显示的相关测试,包括 IIC 设备扫描获取地址,SSD1306 驱动 OLED 设备的连接、工程测试(文字、图片、动画等),为小安派系列产品的数据显示和智能交互相关实验提供了参考。
赞~
  • 会员数: 28579 个
  • 话题数: 40683 篇
