开启辅助访问
设为首页
收藏本站
论坛首页
邀请注册
物联网开发者社区-安信可论坛
论坛首页
模组应用开发
离线语音
VC系列
VC-02 生成不了文件
发新帖
VC-02 生成不了文件
16
3 小时前
显示全部楼层
阅读模式
参考教程
【离线语音专题③】安信可VC系列离线语音SDK开发环境搭建——基于Linux系统
https://bbs.ai-thinker.com/forum ... 0&fromuid=12726
安信可VC-02语音识别模组SDK环境搭建指南
https://www.bilibili.com/opus/936866314436214801
安信可VC-02离线语音模块SDK之Linux环境搭建
https://blog.csdn.net/weixin_52668204/article/details/129833337
cd 进入目录 生成不了文件
root@admin:/home/admina# cd uni_hb_m_solution/unione_lite_app_hb_m/
root@admin:/home/admina/uni_hb_m_solution/unione_lite_app_hb_m# ./build.sh update
2025011801
USER_DEMO_AUTO_GPIO
clean finish
Building file: ../middleware/rtos/freertos/src/croutine.c
Building file: ../middleware/rtos/freertos/src/event_groups.c
Building file: ../middleware/rtos/freertos/src/heap_5s.c
Building file: ../middleware/rtos/freertos/src/list.c
Building file: ../middleware/rtos/freertos/src/os_cpu_a.S
Building file: ../middleware/rtos/freertos/src/port.c
Building file: ../middleware/rtos/freertos/src/portISR.c
Building file: ../middleware/rtos/freertos/src/queue.c
Building file: ../middleware/rtos/freertos/src/tasks.c
Building file: ../middleware/rtos/freertos/src/timers.c
Building file: ../middleware/rtos/rtos_api/rtos_api.c
Building file: ../src/app/src/main.c
Building file: ../src/app/src/uni_record_save.c
Building file: ../src/app/src/uni_session.c
Building file: ../src/app/src/uni_session_manage.c
Building file: ../src/app/src/uni_user_meeting.c
Building file: ../src/app/src/sessions/uni_setting_session.c
Building file: ../src/app/src/sessions/uni_wakeup_session.c
Building file: ../src/app/src/sessions/uni_watchdog_session.c
Building file: ../src/sdk/audio/audio_player/src/uni_audio_player.c
Building file: ../src/sdk/idle_detect/src/idle_detect_service.c
Building file: ../src/sdk/player/src/pcm/src/uni_pcm_player.c
Building file: ../src/sdk/player/src/pcm/src/uni_pcm_resource.c
Building file: ../src/sdk/player/src/uni_media_player.c
Building file: ../src/sdk/player/src/uni_pcm_default.c
Building file: ../src/sdk/vui/src/uni_lasr_result_parser.c
Building file: ../src/sdk/vui/src/uni_nlu.c
Building file: ../src/sdk/vui/src/uni_recog_engine_control.c
Building file: ../src/sdk/vui/src/uni_recog_preproc.c
Building file: ../src/sdk/vui/src/uni_recog_service.c
Building file: ../src/sdk/vui/src/uni_vui_interface.c
Building file: ../src/utils/arpt/src/uni_arpt.c
Building file: ../src/utils/auto_string/src/uni_auto_string.c
Building file: ../src/utils/bitmap/src/uni_bitmap.c
Building file: ../src/utils/black_board/src/uni_black_board.c
Building file: ../src/utils/cJSON/src/cJSON.c
Building file: ../src/utils/cJSON/src/uni_json.c
Building file: ../src/utils/config/src/uni_config.c
Building file: ../src/utils/crc16/src/uni_crc16.c
Building file: ../src/utils/data_buf/src/uni_databuf.c
Building file: ../src/utils/event/src/uni_event.c
Building file: ../src/utils/event_list/src/uni_event_list.c
Building file: ../src/utils/event_route/src/uni_event_route.c
Building file: ../src/utils/float2string/src/uni_float2string.c
Building file: ../src/utils/fsm/src/uni_fsm.c
Building file: ../src/utils/hash/src/bkdr_hash.c
Building file: ../src/utils/interruptable_sleep/src/uni_interruptable.c
Building file: ../src/utils/list/src/list_head.c
Building file: ../src/utils/log/src/uni_log.c
Building file: ../src/utils/string/src/uni_string.c
Building file: ../src/utils/timer/src/uni_timer.c
Building file: ../src/utils/uart/src/uni_communication.c
Building file: ../src/utils/uart/src/uni_uart.c
Building file: ../startup/crt0.S
Building file: ../startup/init-default.c
Building file: ../startup/interrupt.c
Building file: ../startup/retarget.c
Building file: ../startup/flash_boot.c
Building file: ../user/src/user_asr.c
Building file: ../user/src/user_event.c
Building file: ../user/src/user_file.c
Building file: ../user/src/user_flash.c
Building file: ../user/src/user_gpio.c
Building file: ../user/src/user_main.c
Building file: ../user/src/user_player.c
Building file: ../user/src/user_power.c
Building file: ../user/src/user_record.c
Building file: ../user/src/user_uart.c
Building file: ../user/src/user_uni_ucp.c
Building file: ../user/src/user_timer.c
Building file: ../user/src/user_pwm.c
Building file: ../user/src/user_uni_sucp.c
Building file: ../user/src/user_start.c
Building file: ../user/src/examples/hb_smart_ac.c
Building file: ../user/src/examples/hb_uart.c
Building file: ../user/src/examples/hb_uart_ucp.c
Building file: ../user/src/examples/ac_device_simulator.c
Building file: ../user/src/examples/hb_housekeeper.c
Building file: ../user/src/examples/hb_gpio_adc.c
Building file: ../user/src/examples/hb_gpio_key.c
Building file: ../user/src/examples/hb_pwm_led.c
Building file: ../user/src/examples/hb_timer_buzzer.c
Building file: ../user/src/examples/hb_sw_timers.c
Building file: ../user/src/examples/hb_flash_example.c
Building file: ../user/src/examples/hb_asr_control.c
Building file: ../user/src/examples/hb_player.c
Building file: ../user/src/examples/housekeeper_irc.c
Building file: ../user/src/examples/hb_uart_sucp.c
Building file: ../user/src/examples/hb_auto_gpio.c
Building file: ../user/src/examples/hb_power_sleep.c
Building file: ../user/src/examples/drivers/user_ad_gl5528.c
Building file: ../user/src/examples/drivers/user_digital_keys.c
Building file: ../user/src/examples/drivers/user_i2c_ds3231.c
Building file: ../user/src/examples/drivers/user_timer_buzzer.c
Building file: ../user/src/examples/drivers/user_pwm_led.c
Building file: ../user/src/examples/drivers/user_spi_ssd1306.c
Building file: ../user/src/examples/drivers/user_sw_timer.c
Building target: uni_app.adx
Invoking: Andes C Linker
/opt/Andestech/BSPv422/toolchains/nds32le-elf-mculib-v3s/bin/nds32le-elf-gcc -O1 -nostartfiles -static -L"../lib" -mcmodel=medium -ldsp -mext-dsp -T"../nds32-ae210p.ld" -Wl,--gc-sections -mvh -o "uni_app.adx" ./middleware/rtos/freertos/src/croutine.o ./middleware/rtos/freertos/src/event_groups.o ./middleware/rtos/freertos/src/heap_5s.o ./middleware/rtos/freertos/src/list.o ./middleware/rtos/freertos/src/os_cpu_a.o ./middleware/rtos/freertos/src/port.o ./middleware/rtos/freertos/src/portISR.o ./middleware/rtos/freertos/src/queue.o ./middleware/rtos/freertos/src/tasks.o ./middleware/rtos/freertos/src/timers.o ./middleware/rtos/rtos_api/rtos_api.o ./src/app/src/main.o ./src/app/src/uni_record_save.o ./src/app/src/uni_session.o ./src/app/src/uni_session_manage.o ./src/app/src/uni_user_meeting.o ./src/app/src/sessions/uni_setting_session.o ./src/app/src/sessions/uni_wakeup_session.o ./src/app/src/sessions/uni_watchdog_session.o ./src/sdk/audio/audio_player/src/uni_audio_player.o ./src/sdk/idle_detect/src/idle_detect_service.o ./src/sdk/player/src/pcm/src/uni_pcm_player.o ./src/sdk/player/src/pcm/src/uni_pcm_resource.o ./src/sdk/player/src/uni_media_player.o ./src/sdk/player/src/uni_pcm_default.o ./src/sdk/vui/src/uni_lasr_result_parser.o ./src/sdk/vui/src/uni_nlu.o ./src/sdk/vui/src/uni_recog_engine_control.o ./src/sdk/vui/src/uni_recog_preproc.o ./src/sdk/vui/src/uni_recog_service.o ./src/sdk/vui/src/uni_vui_interface.o ./src/utils/arpt/src/uni_arpt.o ./src/utils/auto_string/src/uni_auto_string.o ./src/utils/bitmap/src/uni_bitmap.o ./src/utils/black_board/src/uni_black_board.o ./src/utils/cJSON/src/cJSON.o ./src/utils/cJSON/src/uni_json.o ./src/utils/config/src/uni_config.o ./src/utils/crc16/src/uni_crc16.o ./src/utils/data_buf/src/uni_databuf.o ./src/utils/event/src/uni_event.o ./src/utils/event_list/src/uni_event_list.o ./src/utils/event_route/src/uni_event_route.o ./src/utils/float2string/src/uni_float2string.o ./src/utils/fsm/src/uni_fsm.o ./src/utils/hash/src/bkdr_hash.o ./src/utils/interruptable_sleep/src/uni_interruptable.o ./src/utils/list/src/list_head.o ./src/utils/log/src/uni_log.o ./src/utils/string/src/uni_string.o ./src/utils/timer/src/uni_timer.o ./src/utils/uart/src/uni_communication.o ./src/utils/uart/src/uni_uart.o ./startup/crt0.o ./startup/init-default.o ./startup/interrupt.o ./startup/retarget.o ./startup/flash_boot.o ./user/src/user_asr.o ./user/src/user_event.o ./user/src/user_file.o ./user/src/user_flash.o ./user/src/user_gpio.o ./user/src/user_main.o ./user/src/user_player.o ./user/src/user_power.o ./user/src/user_record.o ./user/src/user_uart.o ./user/src/user_uni_ucp.o ./user/src/user_timer.o ./user/src/user_pwm.o ./user/src/user_uni_sucp.o ./user/src/user_start.o ./user/src/examples/hb_smart_ac.o ./user/src/examples/hb_uart.o ./user/src/examples/hb_uart_ucp.o ./user/src/examples/ac_device_simulator.o ./user/src/examples/hb_housekeeper.o ./user/src/examples/hb_gpio_adc.o ./user/src/examples/hb_gpio_key.o ./user/src/examples/hb_pwm_led.o ./user/src/examples/hb_timer_buzzer.o ./user/src/examples/hb_sw_timers.o ./user/src/examples/hb_flash_example.o ./user/src/examples/hb_asr_control.o ./user/src/examples/hb_player.o ./user/src/examples/housekeeper_irc.o ./user/src/examples/hb_uart_sucp.o ./user/src/examples/hb_auto_gpio.o ./user/src/examples/hb_power_sleep.o ./user/src/examples/drivers/user_ad_gl5528.o ./user/src/examples/drivers/user_digital_keys.o ./user/src/examples/drivers/user_i2c_ds3231.o ./user/src/examples/drivers/user_timer_buzzer.o ./user/src/examples/drivers/user_pwm_led.o ./user/src/examples/drivers/user_spi_ssd1306.o ./user/src/examples/drivers/user_sw_timer.o -lbargein -lual-aik -lengine -lual-osal -lfft_fix_mfcc_nrd -lmatrix_op -ldsp -lunihal -lm
Finished building target: uni_app.adx
Invoking: NM (symbol listing)
/opt/Andestech/BSPv422/toolchains/nds32le-elf-mculib-v3s/bin/nds32le-elf-nm -n -l -C "uni_app.adx" > ../output/symbol.txt
Finished building: ../output/symbol.txt
Invoking: Readelf (ELF info listing)
/opt/Andestech/BSPv422/toolchains/nds32le-elf-mculib-v3s/bin/nds32le-elf-readelf -a "uni_app.adx" > ../output/readelf.txt
Finished building: ../output/readelf.txt
Invoking: Objcopy (object content copy)
/opt/Andestech/BSPv422/toolchains/nds32le-elf-mculib-v3s/bin/nds32le-elf-objcopy -S -O binary "uni_app.adx" ../output/uni_app.bin
Finished building: ../output/uni_app.bin
Invoking: Size (section size listing)
/opt/Andestech/BSPv422/toolchains/nds32le-elf-mculib-v3s/bin/nds32le-elf-size "uni_app.adx" | tee ../output/.PHONY.size
text (code + rodata) data bss dec hex filename
1287878 (256370 + 1031508) 1624 41748 1331250 145032 uni_app.adx
Finished building: ../output/.PHONY.size
1195+1 records in
1195+1 records out
1223992 bytes (1.2 MB, 1.2 MiB) copied, 0.00231735 s, 528 MB/s
clean finish
make: Nothing to be done for 'middleware/rtos/freertos/src/croutine.d'.
mv: cannot stat 'output/uni_app.bin': No such file or directory
沈夜
3 小时前
显示全部楼层
看错了 这个提示 无影响。
支持
反对
发新帖
发表回复
沈夜
48
论坛元老, 积分 6113, 距离下一级还需 9993886 积分
加好友
发消息
回复楼主
VC系列
VD系列
图文推荐
星闪开发板大赠送 | 年终福利第四期开启,biubiu~(活动已停)
2024-12-23
【板子申请流程】新进来的同学请看这里-活动已停
2023-11-08
【中奖公告】申请Ai-M61-32S-kit的同学看过来!
2024-04-29
2024-04-18
我也领到官方免费送的AiPi-Eyes-S1开发板啦!!!
2023-09-26
热门排行
安信可社区一周年狂欢派对&抽奖盖楼活动开
5
优质文章有赏!现金红包+开发板无限送,冲
7
【官方公告】关于板子申请发帖争议解释
8
【轻松上手】小安派跑个超级玛丽
9
【教程】社区发帖教程指引(尤其是图片上传
10
