[PB-03F-kit] 命令行 快速烧录
沈夜
PB&TG系列 804 2 2024-12-2 19:14:27
不是太好配置 尝试失败了,有无大佬 看看 这参数是咋用的。
文档地址=
http://www.phyplusinc.com/support/8.html
获取PhyPlusKit使用指南:
[下载] PhyPlusKit User's Guide v2.3 [CN]
一、烧写PHY6252时,如何让单片机进入烧写模式:加上--dwc UXTDWU就可以了
.\PhyPlusKit.exe -P COM4 -u 1500000 --dwc UXTDWU
二、如何增加MAC地址的烧写:
  • .\PhyPlusKit.exe -P COM11 -e 0 -w ..\ld\mesh_light_phy6222.hexf --mac
  • 4000+1CD6BDBD3DBE
--mac 4000+1CD6BDBD3DBE 的意思是4000是烧写的地址,1CD6BDBD3DBE是MAC值
三、 Preserve模式的地址段保留和多地址段的擦除:
.\PhyPlusKit.exe -P COM11 -e 2 --Addr 4000-5000+4C000-4d000 -w ..\ld\mesh_light_phy6222.hexf
-e 2的意思是格式化采用的模式 0是512K   1是HEXF  2是Preserve 。。。依次类推
构造的 cmd 命令
.\PhyPlusKit.exe -P COM4 -e 2 -w gpio_demo.hex
PhyPlusKit.exe -P COM4 -u 1500000 --dwc UXTDWU -e 0 --Addr 0x11005000 -w gpio_demo_phy6222.hexf
存在一些 问题  进度二就停止了。有无大佬 一起来研究下
UART TX ASCII: UXTDWU
UART RX: cmd>>:
Current port: COM4
Current baudrate: 115200
Current stopBits: 1
Current parity: No
Serial opened!!
Send erase successfully!
Receive #OK!
Erase successfully!
Receive #OK!
=== PHY6222 ===
=== PHY6222 ===
Send update command successfully!
Baud rate modified successfully
Current baudRate: 1500000
=== PHY6222 ===
Receive #OK!
Reset flash successfully!
Receive #OK!
Send spif config command successfully!
Receive #OK!
Spif config successfully!
Send sfmod command successfully!
Receive #OK!
Sfmod select successfully!
Verify efuse success!
Send cpnum successfully!
Receive #OK!
Receive >>: successful!
============Write hexf File [01/03]============
Send cpbin successfully!
UART RX ASCII: by hex mode:
Receive image request!
Send image successful! Waiting to receive checksum...
Send checksum successfully!
UART RX ASCII: checksum is: 0x0001098f#OK>>:
Receive #OK!
============Write hexf File [02/03]============
Receive checksum timeout!
Write images failed!
2024-12-3 08:34:42
给你抓个技术来解决!
之前没看过这个芯片的烧录,但是我看了一下手册,最后应该有操作的命令行,一般都是烧录hexf文件,你大概率是这个-e加密的问题,你可以看看手册最后有合成和烧录的命令行示例
  • 会员数: 28928 个
  • 话题数: 41543 篇
