WB2 原神启动 OLED 显示
查看346 | 回复4 | 4 天前 | 显示全部楼层 |阅读模式
  1. #include "OLED.h"
  2. #include "OLED_Data.h"
  3. int main(void)
  4. {
  5.         /*OLED初始化*/
  6.         OLED_Init();
  7.         OLED_DrawRectangle(0, 0, 128, 64, OLED_FILLED);
  8.         /*在(96, 48)位置显示图像,宽16像素,高16像素,图像数据为Diode数组*/
  9.         OLED_ShowImage(20, 0, 102, 64, gImage_111);
  10.         /*调用OLED_Update函数,将OLED显存数组的内容更新到OLED硬件进行显示*/
  11.         OLED_Update();
  12. }
  1. const uint8_t gImage_111[] = {
  2. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  3. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  4. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  5. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  6. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  7. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  8. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  9. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  10. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  11. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  12. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0x01,0x1F,0xFF,0xFF,0xFF,0xFF,
  13. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  14. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  15. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xDF,
  16. 0xDF,0x1F,0x0F,0x01,0x07,0x0F,0x9F,0xDF,0xDF,0xDF,0xDF,0xDF,0xDF,0xDF,0x5F,0x1F,
  17. 0x1F,0x5F,0xDF,0xDF,0xDF,0xDF,0xDF,0xDF,0xDF,0xDF,0xDF,0xDF,0xDF,0xDF,0x9F,0x8F,
  18. 0x01,0x07,0x8F,0xDF,0xDF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xDF,0x9F,0x87,0x00,
  19. 0x00,0x00,0x83,0x8F,0xDF,0xDF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  20. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  21. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  22. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0x00,0x00,0x00,0x00,0x00,0xFF,0x00,0x00,0x01,
  23. 0x01,0x01,0xDD,0xDD,0xDC,0xDC,0xDC,0xDC,0xDD,0xFD,0x01,0x01,0x00,0x01,0x01,0xFB,
  24. 0xFF,0x05,0x05,0x05,0xFD,0x01,0x00,0x00,0x01,0x30,0x30,0x31,0xF3,0x01,0x00,0x01,
  25. 0x01,0x01,0xBD,0x1D,0x1D,0x05,0x00,0x00,0x0D,0x1D,0x9D,0x01,0x00,0x00,0x00,0x01,
  26. 0xF9,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  27. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  28. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0x7F,0x1F,0x00,0x80,0xC0,
  29. 0x20,0x3C,0x1F,0x18,0x08,0x88,0x8C,0x8C,0xBD,0xFD,0x01,0x01,0x01,0x01,0xFD,0xBD,
  30. 0x88,0x88,0x88,0x08,0x1C,0x1F,0x3F,0x00,0x00,0xC0,0xFF,0x00,0x00,0x00,0x00,0xE0,
  31. 0xE0,0xF0,0xFF,0xC0,0xC0,0xC0,0xE0,0x70,0x7B,0x7B,0x3B,0x1A,0x00,0x00,0x3A,0x3B,
  32. 0x7B,0x70,0xE0,0xC0,0xC0,0xC0,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  33. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  34. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  35. 0xFD,0xFE,0xFE,0xFF,0xFF,0xFF,0xFF,0xFE,0xFC,0xFD,0xFD,0xFF,0xFF,0xFF,0xFF,0xFF,
  36. 0xE0,0xF0,0xF0,0xFC,0xFF,0xFF,0xFF,0xFF,0xFF,0xFD,0xFD,0xFC,0xFE,0xFE,0xFF,0xFF,
  37. 0xFF,0xE0,0xF0,0xF8,0xFE,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFE,
  38. 0xFC,0xC0,0x00,0x00,0xF0,0xFC,0xFE,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  39. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  40. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  41. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  42. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  43. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  44. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0x00,0xFC,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  45. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  46. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  47. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  48. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  49. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  50. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFE,0xFF,
  51. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  52. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  53. };
相关图片 及取好的字模 打包
配套驱动
[Ai-WB2] 移植oled库
https://bbs.ai-thinker.com/forum ... 0&fromuid=12726
0.96oled取模教程
https://bbs.ai-thinker.com/forum ... 2&fromuid=12726
源图片和字模.zip (5.16 KB, 下载次数: 0)
hdydy | 4 天前 | 显示全部楼层
原神启动
爱笑 | 3 天前 | 显示全部楼层
不错不错~
妖猊 | 3 天前 | 显示全部楼层
太厉害了
小小鸟 | 前天 08:32 | 显示全部楼层
66666
