【祖传点灯】安信可Ai-M61-32S Arduino 环境测评 3
dja
Ai-M61-Kit点灯教程 1637 9 2024-5-18 21:27:17
测试 WIFI
代码
#include <WiFi.h>
#define LED1 27
#define LED2 29
void led_init()
    pinMode(LED1, OUTPUT);
    pinMode(LED2, OUTPUT);
void led_on()
    digitalWrite(LED1, HIGH);
    digitalWrite(LED2, HIGH);
void led_off()
    digitalWrite(LED1, LOW);
    digitalWrite(LED2, LOW);
char *ssid = "TP-LINK_A8AB"; // 填入 WIFI 名称
char *pswd = "************"; // 填入 WIFI 密码
void setup()
    led_init();
    led_on();
    delay(1000);
    led_off();
    delay(1000);
    WiFi.begin(ssid, pswd);
    // Will try for about 10 seconds (20x 500ms)
    int tryDelay = 500;
    int numberOfTries = 20;
    while (true)
        switch (WiFi.status())
            case WL_NO_SSID_AVAIL:
                break;
            case WL_CONNECT_FAILED:
                return;
                break;
            case WL_CONNECTION_LOST:
                break;
            case WL_SCAN_COMPLETED:
                break;
            case WL_DISCONNECTED:
                break;
            case WL_CONNECTED:
                led_on();
                return;
                break;
            default:
                break;
        delay(tryDelay);
        if (numberOfTries <= 0)
            // Use disconnect function to force stop trying to connect
            WiFi.disconnect();
            return;
        else
            numberOfTries--;
void loop()
    if (0)
        // Disconnect from WiFi
        WiFi.disconnect();
        delay(1000);
实验
开发板上电之前需要确保 WIFI 已经打开
2024-5-18 21:32:16
预期实验结果:
1. 上电之后,白灯亮起 1 秒,然后熄灭
2. 如果连接 WIFI 成功,那么白灯保持常亮
实验结果:
2024-5-18 22:56:36
可以把MQTT也集成一下
2024-5-19 09:46:17
真不错
2024-5-19 11:38:20
2024-5-20 09:31:12
2024-5-20 11:33:20
不错不错!
2024-5-21 10:54:59
emmmm...希望能详细一点
2024-6-24 14:48:14
不错!
2024-7-28 12:04:15
恭喜
  • 会员数: 28811 个
  • 话题数: 41168 篇
