【已解决】莫哥 HomeAssistant 无法连接HA
7788
智能家居 5448 19 2024-5-11 07:43:43
[i=s] 本帖最后由 7788 于 2024-5-11 13:48 编辑 [/i]<br /> <br />
修改下,本次问题主要原因在于
我配置了docker加速,用的阿里云的
但是阿里云的镜像 有问题
用docker hub的就没问题了
给大家参考下
按着莫哥得教程,
智能家居之旅,第三站:Ai-M61/M62 接入HomeAssistant 实现点灯 - 智能家居 - 物联网开发者社区-安信可论坛 - Powered by Discuz! (ai-thinker.com)
搭建好环境 连接好MQTT,但是,HA不行,没有设备
我按步骤,修改了
配置文件
WiFI
和 ha_device 结构体参数
成功连接了wifi 和 MQTT服务器
我后台HA配置界面
但是HA设备列表里面没有设备
我的HA是最新版
main文件
 * @file main.c
 * @brief
 * @version 0.1
 * @date 2024-01-23
 * @copyright Copyright (c) 2024
#include <FreeRTOS.h>
#include "task.h"
#include "queue.h"
#include "board.h"
#include "bluetooth.h"
#include "btble_lib_api.h"
#include "bl616_glb.h"
#include "rfparam_adapter.h"
#include "bflb_mtd.h"
#include "easyflash.h"
#include "wifi_event.h"
#include "log.h"
#include "aiio_os_port.h"
#include "homeAssistantMQTT.h"
extern
#define DBG_TAG "MAIN"
void ha_event_cb(ha_event_t event, homeAssisatnt_device_t* ha_dev)
    switch (event)
        case HA_EVENT_MQTT_CONNECED:
            LOG_I("<<<<<<<<<<  HA_EVENT_MQTT_CONNECED");
            //一定要加static
            static ha_sw_entity_t entity_sw1 = {
                 .name = "开关1",
                 .icon = "mdi:power",
                 .unique_id = "switch_v1",
            homeAssistant_device_add_entity(CONFIG_HA_ENTITY_SWITCH, &entity_sw1);
            homeAssistant_device_send_status(HOMEASSISTANT_STATUS_ONLINE);
            homeAssistan_device_send_entity_state(CONFIG_HA_ENTITY_SWITCH, &entity_sw1, 0);
            break;
        case HA_EVENT_MQTT_DISCONNECT:
            LOG_I("<<<<<<<<<<  HA_EVENT_MQTT_DISCONNECT");
            break;
        case HA_EVENT_MQTT_COMMAND_SWITCH:
            LOG_I("<<<<<<<<<<  HA_EVENT_MQTT_COMMAND_SWITCH");
            // LOG_I("switch addr =%p", ha_dev->entity_switch->command_switch);
            LOG_I(" switch %s is %s", ha_dev->entity_switch->command_switch->name, ha_dev->entity_switch->command_switch->switch_state?"true":"flase");
            int ret = homeAssistan_device_send_entity_state(CONFIG_HA_ENTITY_SWITCH, ha_dev->entity_switch->command_switch, ha_dev->entity_switch->command_switch->switch_state);
            if (ret!=-1)LOG_I("%s send entity suceess,state=%s", ha_dev->entity_switch->command_switch->name, ha_dev->entity_switch->command_switch->switch_state?"true":"flase");
            break;
        default:
            break;
int main(void)
    board_init();
    bflb_mtd_init();
    easyflash_init();
    // aiio_log_init();
        LOG_E("PHY RF init failed!\r\n");
        return 0;
    staWiFiInit();
    // homeassistant_blufi_init();
    static homeAssisatnt_device_t ha_device;
    ha_device.mqtt_info.mqtt_clientID="Ai-M6X_Kit_Switch";
    ha_device.mqtt_info.mqtt_host="";
    ha_device.mqtt_info.port=1883;
    ha_device.mqtt_info.mqtt_username="";
    ha_device.mqtt_info.mqtt_password="";
    homeAssistant_device_init(&ha_device, ha_event_cb);
    vTaskStartScheduler();
        LOG_F("HomeAssistant free heap size=%d", aiio_os_get_free_heap_size());
        vTaskDelay(pdMS_TO_TICKS(3000));
2024-5-11 08:18:47
2024-5-11 08:36:19
topic 设置的对吗
2024-5-11 08:42:14
让莫哥给你回答一下!
爱笑 发表于 2024-5-11 08:42
让莫哥给你回答一下!
你的host 没设置对,默认连接的是安信可官方的MQTT服务器,不是你的服务器。
你的host 没设置对,默认连接的是安信可官方的MQTT服务器,不是你的服务器。你要给host 这个参数赋值成自己的MQTT服务器地址
补一句,如果你是在配置文件里改了默认的参数,就不用在这赋值host了,会覆盖默认值的
2024-5-11 09:03:15
智能家居这块还得是莫哥
2024-5-11 09:05:24
起个名字好难啊 发表于 2024-5-11 08:51
补一句,如果你是在配置文件里改了默认的参数,就不用在这赋值host了,会覆盖默认值的 ...
莫哥,都改了,你看我MQTT截图,M61已经成功连接上了
2024-5-11 09:11:13
ha_device.mqtt_info.mqtt_username= ...
topic 没设置,这应该是 homeAssistant_device_init 函数配置的吧
  • 会员数: 28955 个
  • 话题数: 41627 篇
