【祖传点灯】安信可Ai-M61-32S + 环境搭建点灯
Wiki
板子申请专区 3629 8 2024-5-4 12:05:42
一、环境搭建
这是论坛大佬做的一款一键搭建环境的傻瓜包:https://www.123pan.com/s/bpGiVv-ijBb.html  提取码:15KF
论坛大佬把我们需要安装完的那个目录打包一下,并修复了各种问题。
这大大降低了我们搭建环境的难度。
二、编译工具路径设置
解压完上面的傻瓜包后,我们需要将以下三个路径添加到环境变量中
三、验证环境
打开PowerShell 。在 PowerShell 输入:
  1. make -v
输入:
  1. riscv64-unknown-elf-gcc -v
成功时输出信息:
  1. Using built-in specs.
  2. COLLECT_GCC=D:\Desktop\AiPi-Open-Kits\aithinker_Ai-M6X_SDK\toolchain_gcc_t-head_windows\bin\riscv64-unknown-elf-gcc.exe
  3. COLLECT_LTO_WRAPPER=d:/desktop/aipi-open-kits/aithinker_ai-m6x_sdk/toolchain_gcc_t-head_windows/bin/../libexec/gcc/riscv64-unknown-elf/10.2.0/lto-wrapper.exe
  4. Target: riscv64-unknown-elf
  5. Configured with: /mnt/ssd/jenkins_iotsw/slave/workspace/Toolchain/build-gnu-riscv/./source/riscv/riscv-gcc/configure --target=riscv64-unknown-elf --host=i686-w64-mingw32 --with-gmp=/mnt/ssd/jenkins_iotsw/slave/workspace/Toolchain/build-gnu-riscv/build-gcc-riscv64-unknown-elf/build-Xuantie-900-gcc-elf-newlib-mingw-V2.6.1/lib-for-gcc-mingw --with-mpfr=/mnt/ssd/jenkins_iotsw/slave/workspace/Toolchain/build-gnu-riscv/build-gcc-riscv64-unknown-elf/build-Xuantie-900-gcc-elf-newlib-mingw-V2.6.1/lib-for-gcc-mingw --with-mpc=/mnt/ssd/jenkins_iotsw/slave/workspace/Toolchain/build-gnu-riscv/build-gcc-riscv64-unknown-elf/build-Xuantie-900-gcc-elf-newlib-mingw-V2.6.1/lib-for-gcc-mingw --with-libexpat-prefix=/mnt/ssd/jenkins_iotsw/slave/workspace/Toolchain/build-gnu-riscv/build-gcc-riscv64-unknown-elf/build-Xuantie-900-gcc-elf-newlib-mingw-V2.6.1/lib-for-gcc-mingw --with-libmpfr-prefix=/mnt/ssd/jenkins_iotsw/slave/workspace/Toolchain/build-gnu-riscv/build-gcc-riscv64-unknown-elf/build-Xuantie-900-gcc-elf-newlib-mingw-V2.6.1/lib-for-gcc-mingw --with-pkgversion='Xuantie-900 elf newlib gcc Toolchain V2.6.1 B-20220906' CXXFLAGS='-g -O2 -DTHEAD_VERSION_NUMBER=2.6.1 ' --enable-libgcctf --prefix=/mnt/ssd/jenkins_iotsw/slave/workspace/Toolchain/build-gnu-riscv/build-gcc-riscv64-unknown-elf/Xuantie-900-gcc-elf-newlib-mingw-V2.6.1 --disable-shared --enable-threads=posix --enable-languages=c,c++ --without-system-zlib --enable-tls --with-newlib --with-sysroot=/mnt/ssd/jenkins_iotsw/slave/workspace/Toolchain/build-gnu-riscv/build-gcc-riscv64-unknown-elf/Xuantie-900-gcc-elf-newlib-mingw-V2.6.1/riscv64-unknown-elf --with-native-system-header-dir=/include --disable-libmudflap --disable-libssp --disable-libquadmath --disable-libgomp --disable-nls --disable-tm-clone-registry --src=/mnt/ssd/jenkins_iotsw/slave/workspace/Toolchain/build-gnu-riscv/./source/riscv/riscv-gcc --enable-multilib --with-abi=lp64d --with-arch=rv64gcxthead 'CFLAGS_FOR_TARGET=-Os   -mcmodel=medany' 'CXXFLAGS_FOR_TARGET=-Os   -mcmodel=medany'
  6. Thread model: posix
  7. Supported LTO compression algorithms: zlib zstd
  8. gcc version 10.2.0 (Xuantie-900 elf newlib gcc Toolchain V2.6.1 B-20220906)
这样,我们的前期工作就做好了!!
四、开始点灯
  • 用VScode开发工程文件夹
  • 选择点灯工程-AiPi-Eyes-DU,右键在终端打开
然后在终端输入:
  1. make
这样就代表编译成功
五、烧录程序
在烧录之前,我们要先按着IO2,然后按一下EN再松开EN,最后松开IO2,进入下载模式
终端 运行指令:
  1. make flash COMX=COMxx
支持下
2024-6-21 10:54:10
入坑了
恭喜点灯
2024-7-4 14:14:10
真详细
2024-10-6 14:51:28
666
2024-11-18 16:17:30
厉害的
2024-11-20 14:43:14
真棒!希望我能也能亲手开发一下
  • 会员数: 30628 个
  • 话题数: 44727 篇
