Ai-WB2-32S MQTT TCP使用
黎明将至!
Ai-WB2系列 1351 12 2024-2-21 18:14:12
前言
本期博客来介绍一下关于mqtt中tcp的demo的使用。
一、使用步骤
第一步 进入mqtt/tcp目录
cd ~/Ai-Thinker-WB2/applications/protocols/mqtt/tcp
第二步 修改main.c文件内容
gedit ./tcp/main.c
#include <FreeRTOS.h>
#include <task.h>
#include <stdio.h>
#include <string.h>
#include "blog.h"
#include <aos/yloop.h>
#include <aos/kernel.h>
#include <lwip/tcpip.h>
#include <wifi_mgmr_ext.h>
#include <hal_wifi.h>
#define ROUTER_SSID "1234567"  //自行修改WiFi名称
#define ROUTER_PWD "202013076"   //自行修改WiFi密码
static wifi_conf_t conf =
    .country_code = "CN",
static void wifi_sta_connect(char* ssid, char* password)
    wifi_interface_t wifi_interface;
    wifi_interface = wifi_mgmr_sta_enable();
    wifi_mgmr_sta_connect(wifi_interface, ssid, password, NULL, NULL, 0, 0);
static void event_cb_wifi_event(input_event_t* event, void* private_data)
    switch (event->code)
        case CODE_WIFI_ON_INIT_DONE:
            blog_info("[APP] [EVT] INIT DONE %lld", aos_now_ms());
            wifi_mgmr_start_background(&conf);
        break;
        case CODE_WIFI_ON_MGMR_DONE:
            blog_info("[APP] [EVT] MGMR DONE %lld", aos_now_ms());
            wifi_sta_connect(ROUTER_SSID, ROUTER_PWD);
        break;
        case CODE_WIFI_ON_SCAN_DONE:
            blog_info("[APP] [EVT] SCAN Done %lld", aos_now_ms());
        break;
        case CODE_WIFI_ON_DISCONNECT:
            blog_info("[APP] [EVT] disconnect %lld", aos_now_ms());
        break;
        case CODE_WIFI_ON_CONNECTING:
            blog_info("[APP] [EVT] Connecting %lld", aos_now_ms());
        break;
        case CODE_WIFI_CMD_RECONNECT:
            blog_info("[APP] [EVT] Reconnect %lld", aos_now_ms());
        break;
        case CODE_WIFI_ON_CONNECTED:
            blog_info("[APP] [EVT] connected %lld", aos_now_ms());
        break;
        case CODE_WIFI_ON_PRE_GOT_IP:
        break;
        case CODE_WIFI_ON_GOT_IP:
            blog_info("[APP] [EVT] GOT IP %lld", aos_now_ms());
            blog_info("[SYS] Memory left is %d Bytes", xPortGetFreeHeapSize());
            extern void mqtt_start(void);
            mqtt_start();
        break;
        case CODE_WIFI_ON_PROV_SSID:
        break;
        case CODE_WIFI_ON_PROV_BSSID:
            blog_info("[APP] [EVT] [PROV] [BSSID] %lld: %s",
                   aos_now_ms(),
                   event->value ? (const char*)event->value : "UNKNOWN");
            if (event->value)
                vPortFree((void*)event->value);
        break;
        case CODE_WIFI_ON_PROV_PASSWD:
        break;
        case CODE_WIFI_ON_PROV_CONNECT:
        break;
        case CODE_WIFI_ON_PROV_DISCONNECT:
            blog_info("[APP] [EVT] [PROV] [DISCONNECT] %lld", aos_now_ms());
        break;
        default:
            blog_info("[APP] [EVT] Unknown code %u, %lld", event->code, aos_now_ms());
            /*nothing*/
static void proc_main_entry(void* pvParameters)
    aos_register_event_filter(EV_WIFI, event_cb_wifi_event, NULL);
    hal_wifi_start_firmware_task();
    aos_post_event(EV_WIFI, CODE_WIFI_ON_INIT_DONE, 0);
    vTaskDelete(NULL);
void main()
    blog_set_level_log_component(BLOG_LEVEL_WARN, "tcp");
    blog_set_level_log_component(BLOG_LEVEL_WARN, "axk_mqtt");
    blog_set_level_log_component(BLOG_LEVEL_WARN, "tcp_transport");
    puts("[OS] Starting TCP/IP Stack...");
    tcpip_init(NULL, NULL);
    puts("[OS] proc_main_entry task...");
    xTaskCreate(proc_main_entry, (char*)"main_entry", 1024, NULL, 15, NULL);
第三步 修改demo.c文件内容
gedit ./tcp/demo.c
第四步 修改另一个客户端的订阅和发布
二、编译与烧录
第一步 编译
执行make -j8(这里-j8是要参与编译的内核的总数量)
第二步 烧录
将模组连接到电脑上 之后将模组连接到虚拟机上,如下图位置可选择连接
之后执行make flash p=/dev/ttyUSB0 b=115200
跟着提示按下模组的RST键
三、查看运行效果
第一步 断开模组与虚拟机的连接
第二步 打开串口调试助手并连接模组的串口
第三步 重新按下模组的RST键
第四步 查看另一个客户端并发布topic
第五步 查看串口调试助手是否接收到客户端发来的消息
原链接:[https://blog.csdn.net/qq_54193285/article/details/136107369?spm=1001.2014.3001.5501](https://blog.csdn.net/qq_54193285/article/details/136107369?spm=1001.2014.3001.5501)
2024-2-21 21:41:32
这教程真多
2024-2-22 08:39:55
2024-2-22 09:02:16
非常不错
2024-2-22 09:14:35
2024-2-22 09:46:39
2024-2-22 09:53:24
2024-2-22 10:42:46
2024-2-22 10:43:00
2024-2-22 11:21:15
  • 会员数: 28097 个
  • 话题数: 39303 篇
