AI-WB2-01S Unknown cmd:AT+HTTPRAW 不支持
chenduoduo
新手上路
新手上路
Ai-WB2系列 2380 9 2024-1-1 19:16:37
刚买的 WB2-01S 应该是2388固件,看帮助指令里面都有,但实际测试 SNTP AT 命令集  AT+ HTTPRAW  AT+WDISCONNECT 全部都是Unknown cmd,  AT+HELP打印出来也的确没有。请问我是这个型号不支持,还是固件版本不支持,有没有知道的朋友?
arch:BL602,NULL
company:Ai-Thinker|B&T
AT+WMODE=1,1
ble_mac:b40ecf516de4
wifi_mac:b40ecf516de3
sdk_ve
[18:54:19.020]接收←rsion:release_bl_iot_sdk_1.6.40
firmware_version:release/V4.18_P23.0.0
OK
compile_time:Oct  9 2023 17:48:19
2024-1-1 20:26:55
是不是你输入法的问题
2024-1-1 22:14:58
一起学习
2024-1-2 07:46:37
WangChong 发表于 2024-1-1 20:26
是不是你输入法的问题
不是啊,我直接从文档复制黏贴过去也一样,你们的都能使用么?
我买了好几块都这样,要么是芯片型号不支持,要么是固件不支持
2024-1-2 08:42:02
马上抓个技术给你解决!
2024-1-2 09:00:07
打印出来的全部指令列表
[08:58:27.991]发送→AT+HELP
[08:58:28.053]接收←AT+HELP
AT:Test cmd
AT+HELP:Show cmd list
AT+RST:Soft restart
AT+RESTORE:Restore setting
ATE0isable echo
ATE1:Enable ech
[08:58:28.188]接收←o
AT+GMR:Show version info
AT+SLEEP:Set low power mode
AT+UARTCFGuery and set AT UART config
AT+SYSIOMAPuery and set IO map
AT+SYSGPIOWRITE:Set GPIO ou
[08:58:28.358]接收←t level
AT+SYSGPIOREAD:Get GPIO level
AT+PWMCFG:Set PWM config
AT+PWMCFGS:Set PWM config
AT+PWMSTOP:Stop PWM function
AT+PWMDUTYSET:Update PWM duty
AT+PWM
[08:58:28.523]接收←DUTYSETS:Update PWM duty
AT+WMODEuery an set WIFI mode
AT+WSCAN:Scan WIFI list
AT+WSCANOPT:Scan WIFI list option
AT+WSDHCP
[08:58:28.658]接收←uery and set STA DHCP
AT+WJAP:Join AP
AT+WAUTOCONN:Set WIFI auto connect
AT+WAPDHCPuery and set AP DHCP
AT+WAPuery and set AP config
AT+PINGing test
AT+CIPSTAMAC_DEFuery and se
[08:58:28.857]接收←t WIFI station MAC
AT+WCOUNTRYuery and set country code
AT+WCONFIGuery and set wifi config
AT+WRSSIuery RSSI
AT+BLEMAC:Query and set BLE MAC
AT+BLEMO
[08:58:29.023]接收←DE:Query and set BLE mode
AT+BLERFPWR:Query and set BLE RF power
AT+BLESTATE:Query BLE connect status
AT+BLEDISCONissconnec
[08:58:29.158]接收←t BLE
AT+BLEMTU:Query and set BLE MTU
AT+BLESEND:Send by BLE transparent transmission
AT+BLESERUUID:Query and set BLE TT server UUID
AT+BLETXUUID:Query and
[08:58:29.324]接收←set BLE Tx UUID
AT+BLERXUUID:Query and set BLE Rx UUID
AT+TRANSENTER:Start BLE transparent transmission
AT+BLENAME:Query and set BLE name
AT+BLECONINTV:Query and set BLE connect interval
AT+BLEAUTH:Query and set BLE PIN code
AT+BLEADVINTV:Query and set BLE broadcast time
AT+BLEADV
[08:58:29.624]接收←DATA:Query and set BLE broadcast data
AT+BLEADVEN:Query and set BLE broadcast status
AT+BLESCAN:Start BLE scan
AT+BLECONNECT:Start BLE connect
AT+BLEAUTOCON
[08:58:29.789]接收←:Start BLE atuo connect
AT+BLEDISAUTOCON:Turn off BLE atuo connect
AT+BLEIBCNUUID:Query and set BLE iBeacon UUID
AT+BLEIBCNDA
[08:58:29.924]接收←TA:Set BLE iBeacon data
AT+HTTTPCLIENTLINE:Initiate an http or https request
AT+HTTPCLIENTLINE:Initiate an http or https request
AT+MQTT:Config and connect M
[08:58:30.089]接收←QTT
AT+MQTTPUBublish MQTT message
AT+MQTTPUBRAWublish long MQTT message
AT+MQTTSUB:Subscribe MQTT Topic
AT+MQTTUNSUB:Uns
[08:58:30.225]接收←ubscribe MQTT Topic
AT+SOCKET:Create socket
AT+SOCKETSEND:Socket send data
AT+SOCKETSENDLINE:Socket send data in one line
AT+SOCKETREAD:Socket read data
AT
[08:58:30.392]接收←+SOCKETDELelete socket
AT+SOCKETRECVCFG:Set socket recive mode
AT+SOCKETTT:Start socket transparent transmission
AT+SOCKETAUTOTT:Set socket auto transparent transmission
AT+SSLCRET:Query and set SSL Cret
OK
发一下具体的指令LOG哈,这个HTTPRAW的参数挺多的。
2024-1-2 09:17:06
[09:10:03.115]发送→AT+HTTPRAW=1,3,"text/html","192.168.8.88",58888,"/api/kit_api.asp?go=sd",30
[09:10:03.212]接收←AT+HTTPRAW=1,3,"text/html","192.168.8.88",58888,"/api/kit_api.asp?go=sd",30
AT+HTTPCLIENTLIN 可以正常使用
另外SNTP的指令也不支持
[09:15:11.718]发送→AT+SNTPTIMECFG=1,8,cn.ntp.org.cn
[09:15:11.799]接收←AT+SNTPTIMECFG=1,8,cn.ntp.org.cn
[09:15:11.844]接收←
Unknown cmd:AT+SNTPTIMECFG
[09:15:14.585]发送→AT+SNTPTIME?
[09:15:14.653]接收←AT+SNTPTIME?
HELP里面有的指令都能使用,不能使用的在HELP列表里面都不存在,不知道是哪儿不对
2024-1-2 09:20:20
WB2-01S,2388固件,淘宝官方买的,正常HELP打印出来应该有哪些指令
[09 ...
看一下官网的指令集哈,HTTPRAW的域名IP这些不需要双引号的。具体的问题你可以在淘宝问,有相关的技术交流QQ群。
  • 会员数: 29464 个
  • 话题数: 42782 篇
