VC-02 Uart Command
kkjbeat
新手上路
新手上路
VC系列 1215 8 2023-12-18 15:28:39
Hello
I am asking if there is a way to wake up by connecting VC-02 module RS232 and sending HEX Command (HEX). If there is a way, please also teach me the format of setting up and sending data. Thank you.
ex)hey pudding -> 0x5a 0x0 0x0 0x0 0x5a
2023-12-18 15:52:53
2023-12-18 16:42:37
2023-12-18 16:47:20
2023-12-19 09:08:54
Hellow,
           Firstly, VC-02 only supports UART. If you need to use RS232, you will need to add an additional level conversion chip. Secondly, if using serial port wake-up, secondary development is required. You need to set special receive instructions to wake up VC-02 and make logical judgments in the serial port callback function. Finally, thank you for using Ai-Thinker's products. If you have any questions, we will consult us promptly.
        Yours,
        Ai-Thinker XiaoZe
2023-12-19 09:59:21
Ai-Thinker小泽 发表于 2023-12-19 09:50
Hellow,
           Firstly, VC-02 only supports UART. If you need to use RS232, you will need to ad ...
Hello
I want a clearer answer.
1. Is it possible to wake up with UART? If possible, change the method
Give them.
2. Does the second development need to be done mean that it cannot be composed of SDK at the moment?
Thank you.
Yeah, we have a wake-up function API. The serial port is always communicating. You can wake up through the serial port and call the wake-up API after identifying the corresponding serial port instructions. The online platform is currently unable to meet this requirement, but the platform will provide a complete SDK that can be used for secondary development and implementation.
2023-12-19 15:05:10
  • 会员数: 29481 个
  • 话题数: 42794 篇
