【板子申请】Ai-M61-32S开发环境搭建成功
kylin
板子申请专区 691 2 2023-11-12 17:41:57
vscode git 之前都有装过,直接下载代码:
1. api库
2.拉取子模块
  1. cd AiPi-Open-Kits/
[backcolor=rgba(27, 31, 35, 0.05)]修改.gitmodules文件,改成gitee
  1. url = https://gitee.com/Ai-Thinker-Open/aithinker_Ai-M6X_SDK.git
  1. git submodule init
  2. git submodule update  这个可能比较慢,要等久点
3.拉取[size=1.25em]Windows 的编译工具链
[size=1.25em]进入文件夹aithinker_Ai-M6X_SDK,
成功后再拉取子模块
[backcolor=rgba(27, 31, 35, 0.05)]4.设置环境,
因为有其他开发环境,直接改环境变量会引起其它代码编译问题,所以增加一个设置环境变量的脚本setpath.ps1
  1. # Define the path you want to check and add
  2. $PathToCheck = "F:\AiPi\AiPi-Open-Kits\aithinker_Ai-M6X_SDK\tools\make;F:\AiPi\AiPi-Open-Kits\aithinker_Ai-M6X_SDK\toolchain_gcc_t-head_windows\bin;F:\AiPi\AiPi-Open-Kits\aithinker_Ai-M6X_SDK\tools\ninja;"
  3. # Get the current value of the PATH variable
  4. $CurrentPath = [System.Environment]::GetEnvironmentVariable("PATH", "Machine")
  5. $NewPath = $PathToCheck + $CurrentPath
  6. #Set the New Path
  7. [System.Environment]::SetEnvironmentVariable("PATH", $NewPath)
  8. Write-host -f Green "Added '$PathToCheck' to 'Path' Variable!"
每次编译时运行下setpath.ps1
在目录AiPi-Open-Kits上打开powershell
测试make -v
5.下面测试编译AiPi-Eyes_weather
cd AiPi-Eyes_weather
运行 make
最后编译成功
2023-11-12 20:18:45
插个眼给七哥看
2023-11-25 18:07:51
插个眼给园长看
  • 会员数: 30475 个
  • 话题数: 44644 篇
