请
后使用快捷导航
没有账号?
板子申请专区
【板子申请】Ai-M61-32S开发环境搭建_cp换成copy ...
zw6893
中级会员, 积分 341, 距离下一级还需 159 积分
3人留言
楼主
板子申请专区
674
2023-11-10 21:24:00
# 1.安装VSCODE **安装vscode并且安装中文插件**  # 2.安装git工具 **发布页:**[Releases · git-for-windows/git · GitHub]([https://github.com/git-for-windows/git/releases](https://github.com/git-for-windows/git/releases)) [[https://github.com/git-for-windows/git/releases/download/v2.41.0.windows.3/Git-2.41.0.3-64-bit.exe](https://github.com/git-for-windows/git/releases/download/v2.41.0.windows.3/Git-2.41.0.3-64-bit.exe)]([https://github.com/git-for-windows/git/releases/download/v2.41.0.windows.3/Git-2.41.0.3-64-bit.exe](https://github.com/git-for-windows/git/releases/download/v2.41.0.windows.3/Git-2.41.0.3-64-bit.exe)) # 3.克隆源码 **克隆源码** `git clone [https://gitee.com/Ai-Thinker-Open/AiPi-Open-Kits.git`](https://gitee.com/Ai-Thinker-Open/AiPi-Open-Kits.git`) **子模块aithinker_Ai-M6X_SDK更新** 将`AiPi-Open-Kits`下面的`.gitmodules`文件中github替换成gitee。 然后执行 ``` cd aithinker_Ai-M6X_SDK/ git submodule init git submodule update ``` > aithinker_Ai-M6X_SDK 拉取的时间可能会比较久  **aithinker_Ai-M6X_SDK的子模块更新** 进入到`aithinker_Ai-M6X_SDK`文件夹中在git中执行: ``` git submodule init git submodule update ``` > 两个模块的拉取也需要等一会儿  **克隆编译工具栏** 在`aithinker_Ai-M6X_SDK`打开git ``` git clone [https://gitee.com/bouffalolab/toolchain_gcc_t-head_windows.git](https://gitee.com/bouffalolab/toolchain_gcc_t-head_windows.git) ```  # 4.添加环境变量 **将以下变量加入电脑环境变量:** ``` aithinker_Ai-M6X_SDK\toolchain_gcc_t-head_windows\bin aithinker_Ai-M6X_SDK\tools\make aithinker_Ai-M6X_SDK\tools\ninja ``` > 以自己实际绝对路径为主 >  **验证** ``` make -v riscv64-unknown-elf-gcc -v ```  成功 # 5.编译天气站程序 进入`AiPi-Open-Kits`下的`AiPi-Eyes_weather`文件夹 打开CMD,输入`make` 然后等待编译过程:  成功了、吗? 看起来是最后将完成的edata.bin文件从aithinker_Ai-M6X_SDK文件价下拷贝到当前的build文件夹下出了问题 **cp命令换成copy** 1.确认edata.bin文件确实是存在的:  2.确认一下`AiPi-Eyes_weather`模块的`Makefile`文件  实际上指向是aithinker_Ai-M6X_SDK文件下面的`project.build`  CMD不支持cp命令,所以这里要改成copy命令;其次要使用反斜杠(\)而不是正斜杠(/)作为路径分隔符。比如: ``` copy /y a.txt .\to # 将 a.txt 文件复制到 to文件夹下面,/y 代表强制覆盖 ``` 那么**暂时**就这么改:   然后再make:  完成
3 回复
电梯直达
正序浏览
倒序浏览
正序浏览
沙发
Jun
2023-11-10 21:27:52
写的很详细,加油
板凳
iiv
2023-11-25 21:43:22
插个眼给园长看
地板
2023-11-28 14:07:53
通过,私信你了。
BW20-12F-KIT usbd_inic_dplus问题
BU04 原理图
[WB2] 实现自动发现局域网下的设备
星闪连接个数
小安派-Eyes-S1 - GPIO中断编程
智能环境监测系统可行性猜想
论坛应该出一个发帖时间排序
BU04 原理图
小安派-Eyes-S1 - UART
会员数: 30562 个
话题数: 44709 篇
