ESP8266 12f开发板G9引脚不能用作GPIO
查看4080 | 回复0 | 2022-4-6 14:59:37 | 显示全部楼层 |阅读模式
mainn.py脚本如下:
from machine import Pin
import time
p9 = Pin(9, Pin.IN)
while True:
    if(p9.value()==0):
        print("OK")
        time.sleep_ms(1000)
报错如下:
MicroPython v1.18 on 2022-01-17; ESP module (1M) with ESP8266
Type "help()" for more information.
Sending main.py...
SUCCESS: 146 bytes written
MPY: soft reboot
G10可以G9不可以,G9用作输出也不行,输入也不行。
