【BW21-CBV-Kit 开发套件测评】蓝牙小彩灯
无垠的广袤
小安派·BW21-CBV-KIt 255 6 2025-3-26 23:55:45
[i=s] 本帖最后由 无垠的广袤 于 2025-3-27 11:22 编辑 [/i]
本文介绍了安信可 BW21-CBV-Kit 开发套件实现蓝牙小彩灯的项目设计。
介绍
结合示例程序 PWM_over_BLEUart ,实现手机应用蓝牙串口传输,进而控制开发板引脚 PWM 输出,以更改 RGB 三色 LED 的亮度实现无极调光。
硬件连接
如图所示,将 RGB-LED 模块的红、绿、蓝引脚分别连接至开发板的 Arduino 1、2、3 引脚,
这里使用共阴极 LED,公共引脚连接至 GND;若采用共阳极则接至 3.3V 即可。
三色 LED 模块原理图
RGB-LED 模块详见:https://oshwhub.com/jinleili/rgb-led-module
代码解析
 #include "BLEDevice.h"
 // Choose the RGB LED type
 // #define AnodeRGB
 #define CathodeRGB
 // Choose 3 PWM pins for RGB LED pins refer to the pinmap of using board
 #define LED_RED 1
 #define LED_GRN 2
 #define LED_BLU 3
 #define UART_SERVICE_UUID      "6E400001-B5A3-F393-E0A9-E50E24DCCA9E"
 #define CHARACTERISTIC_UUID_RX "6E400002-B5A3-F393-E0A9-E50E24DCCA9E"
 #define CHARACTERISTIC_UUID_TX "6E400003-B5A3-F393-E0A9-E50E24DCCA9E"
 #define STRING_BUF_SIZE 100
 BLEService UartService(UART_SERVICE_UUID);
 BLECharacteristic Rx(CHARACTERISTIC_UUID_RX);
 BLECharacteristic Tx(CHARACTERISTIC_UUID_TX);
 BLEAdvertData advdata;
 BLEAdvertData scndata;
 bool notify = false;
 void readCB(BLECharacteristic* chr, uint8_t connID)
     printf("Characteristic %s read by connection %d \n", chr->getUUID().str(), connID);
 void writeCB(BLECharacteristic* chr, uint8_t connID)
     printf("Characteristic %s write by connection %d :\n", chr->getUUID().str(), connID);
     uint16_t datalen = chr->getDataLen();
     if (datalen > 0) {
         if (chr->readData8() == '!') {
             uint8_t command[datalen];
             chr->getData(command, datalen);
             if (command[1] == 'C') {
                 // print hex
                 printf("Color command R = %x G = %x B = %x \n", command[2], command[3], command[4]);
                 // print decimal
                 // printf("Color command R = %d G = %d B = %d \n", command[2], command[3], command[4]);
 #if defined(CathodeRGB)
                 analogWrite(LED_RED, command[2]);
                 analogWrite(LED_GRN, command[3]);
                 analogWrite(LED_BLU, command[4]);
 #elif defined(AnodeRGB)
                 analogWrite(LED_RED, (255 - command[2]));
                 analogWrite(LED_GRN, (255 - command[3]));
                 analogWrite(LED_BLU, (255 - command[4]));
 #else
                 printf("Error, please choose the RGB LED type \n");
 #endif
         } else {
             Serial.print("Received string: ");
             Serial.print(chr->readString());
             Serial.println();
 void notifCB(BLECharacteristic* chr, uint8_t connID, uint16_t cccd)
     if (cccd & GATT_CLIENT_CHAR_CONFIG_NOTIFY) {
         printf("Notifications enabled on Characteristic %s for connection %d \n", chr->getUUID().str(), connID);
         notify = true;
     } else {
         printf("Notifications disabled on Characteristic %s for connection %d \n", chr->getUUID().str(), connID);
         notify = false;
 void setup()
     Serial.begin(115200);
     pinMode(LED_RED, OUTPUT);
     pinMode(LED_GRN, OUTPUT);
     pinMode(LED_BLU, OUTPUT);
     analogWrite(LED_RED, 255);
     analogWrite(LED_GRN, 255);
     analogWrite(LED_BLU, 255);
     advdata.addFlags(GAP_ADTYPE_FLAGS_LIMITED | GAP_ADTYPE_FLAGS_BREDR_NOT_SUPPORTED);
     advdata.addCompleteName("AMEBA_BLE_DEV");
     scndata.addCompleteServices(BLEUUID(UART_SERVICE_UUID));
     Rx.setWriteProperty(true);
     Rx.setWritePermissions(GATT_PERM_WRITE);
     Rx.setWriteCallback(writeCB);
     Rx.setBufferLen(STRING_BUF_SIZE);
     Tx.setReadProperty(true);
     Tx.setReadPermissions(GATT_PERM_READ);
     Tx.setReadCallback(readCB);
     Tx.setNotifyProperty(true);
     Tx.setCCCDCallback(notifCB);
     Tx.setBufferLen(STRING_BUF_SIZE);
     UartService.addCharacteristic(Rx);
     UartService.addCharacteristic(Tx);
     BLE.init();
     BLE.configAdvert()->setAdvData(advdata);
     BLE.configAdvert()->setScanRspData(scndata);
     BLE.configServer(1);
     BLE.addService(UartService);
     BLE.beginPeripheral();
 void loop()
     if (Serial.available()) {
         Tx.writeString(Serial.readString());
         if (BLE.connected(0) && notify) {
             Tx.notify(0);
     delay(100);
详见瑞昱官方链接: https://www.amebaiot.com/en/amebapro2-arduino-ble-pwm/
编译上传
  • 打开示例程序 PWM_over_BLEUart
  • 按住 BOOT(下载) 按钮的同时按一下 EN(复位)按钮,进入下载模式;
  • 选择目标串口对应的端口号,点击 Download 按钮,待上传成功提示 Success,完成固件上传;
  • 再次短按 EN 键复位,执行程序。
测试流程
手机安装并打开 Adafruit Bluefruit LE Connect 应用;
打开手机蓝牙开关,扫描周围蓝牙设备,连接目标 AMEBA_BLE_DEV
依次选择 Controller - Color Picker - 点击色环及 SELECT 显示目标颜色。
效果展示
总结
本文介绍了安信可 BW21-CBV-Kit 开发套件实现蓝牙小彩灯的项目设计,包括项目介绍、代码分析、操作流程、效果展示等,为无线控制等物联网应用的开发设计提供了参考。
2025-3-27 09:16:37
整活不停~
2025-3-27 09:38:15
2025-3-27 09:46:57
好玩
2025-3-27 10:40:18
嘿嘿😏
2025-3-27 16:41:52
还单独花了个彩灯小pcb?
2025-3-27 20:13:19
HaydenHu 发表于 2025-3-27 16:41
还单独花了个彩灯小pcb?
哈哈,被你发现了
正好手边有多余的 RGB LED 器件和 PCB 券,所以单独设计个模块,效果不错哦
  • 会员数: 28860 个
  • 话题数: 41333 篇
