AI-WB2的easyflash文件系统,刷写程序、OTA后不掉数据哦
小何
Ai-WB2系列 312 4 2025-3-14 19:47:32
移植easyflash和另一个spiffs文件系统刷写程序、OTA后不掉数据原理都差不多,这里再说一次
忙里偷闲发个AI-WB2的SPIFFS文件系统,刷写程序、OTA后不掉数据哦
查看项目下的Make File
# This is a project Makefile. It is assumed the directory this Makefile resides in is a
# project subdirectory.
PROJECT_NAME := LivingRoomCock
PROJECT_PATH := $(abspath .)
PROJECT_BOARD := evb
export PROJECT_PATH PROJECT_BOARD
#CONFIG_TOOLPREFIX :=
-include ./proj_config.mk
ifeq ($(origin BL60X_SDK_PATH), undefined)
BL60X_SDK_PATH_GUESS ?= $(shell pwd)
BL60X_SDK_PATH ?= $(BL60X_SDK_PATH_GUESS)/../../../..
$(info ****** Please SET BL60X_SDK_PATH ******)
$(info ****** Trying SDK PATH [$(BL60X_SDK_PATH)])
endif
COMPONENTS_NETWORK := sntp dns_server
COMPONENTS_BLSYS   := bltime blfdt blmtd blota bloop loopadc looprt loopset
COMPONENTS_VFS     := romfs cjson
INCLUDE_COMPONENTS += freertos_riscv_ram bl602 bl602_std newlibc wifi wifi_manager wpa_supplicant bl602_os_adapter wifi_hosal hosal mbedtls_lts lwip lwip_dhcpd vfs yloop utils cli aws-iot httpc httpd dns_server netutils blog blog_testc
INCLUDE_COMPONENTS += easyflash4 coredump lwip_altcp_tls_mbedtls  blcrypto_suite bl_os_adapter rfparam_adapter_tmp spiffs
INCLUDE_COMPONENTS += $(COMPONENTS_NETWORK)
INCLUDE_COMPONENTS += $(COMPONENTS_BLSYS)
INCLUDE_COMPONENTS += $(COMPONENTS_VFS)
INCLUDE_COMPONENTS += $(PROJECT_NAME)
include $(BL60X_SDK_PATH)/make_scripts_riscv/project.mk
最终调用make_scripts_riscv/project.mk
flash-only:
        cd $(BL60X_SDK_PATH)/tools/flash_tool && env SDK_APP_BIN=$(APP_BIN) SDK_BOARD=$(PROJECT_BOARD) SDK_NAME=$(PROJECT_NAME) SDK_MEDIA_BIN=$(APP_MEDIA_BIN) SDK_ROMFS_DIR=$(APP_ROMFS_DIR) SDK_DTS=$(PROJECT_DTS) SDK_XTAL=$(PROJECT_BOARD_XTAL) BL_FLASH_TOOL_INPUT_PATH_cfg2_bin_input=$(APP_BIN) $(FLASH_TOOL_TYPE) --chipname=BL602 --baudrate=$(SERIAL_BAUDRATE) --port=$(SERIAL_PORT) --pt=$(BL60X_SDK_PATH)/tools/flash_tool/chips/bl602/partition/partition_cfg_4M.toml --dts=$(BL60X_SDK_PATH)/tools/flash_tool/chips/bl602/device_tree/04-bl_factory_params_IoTKitA_40M-20220625.dts --boot2=$(BL60X_SDK_PATH)/tools/flash_tool/chips/bl602/builtin_imgs/boot2_isp_bl602_v6.5.1/boot2_iap_release.bin --firmware=$(APP_BIN)
最终得出Flash分区文是/tools/flash_tool/chips/bl602/partition/partition_cfg_4M.toml
备份文件partition_cfg_4M.toml文件
增加easyflash文件系统分区
[pt_table]
#partition table is 4K in size
address0 = 0xE000
address1 = 0xF000
[[pt_entry]]
type = 0
name = "FW"
device = 0
address0 = 0x10000
size0 = 0x100000
address1 = 0x110000
size1 = 0x100000
# compressed image must set len,normal image can left it to 0
len = 0
[[pt_entry]]
type = 0
name = "spiffs"
device = 0
address0 = 0x210000
size0 = 0x28000
address1 = 0x238000
size1 = 0x8000
len = 0
[[pt_entry]]
type = 2
name = "mfg"
device = 0
address0 = 0x240000
size0 = 0x32000
address1 = 0
size1 = 0
len = 0
[[pt_entry]]
type = 3
name = "media"
device = 0
address0 = 0x272000
size0 = 0x1000
address1 = 0
size1 = 0
len = 0
[[pt_entry]]
type = 4
name = "PSM"
device = 0
address0 = 0x273000
size0 = 0x33000
address1 = 0
size1 = 0
len = 0
[[pt_entry]]
type = 5
name = "KEY"
device = 0
address0 = 0x2A6000
size0 = 0x2000
address1 = 0
size1 = 0
len = 0
[[pt_entry]]
type = 6
name = "DATA"
device = 0
address0 = 0x2A8000
size0 = 0x5000
address1 = 0
size1 = 0
len = 0
[[pt_entry]]
type = 7
name = "factory"
device = 0
address0 = 0x2AD000
size0 = 0x7000
address1 = 0
size1 = 0
len = 0
#if user want to put RF calibration data on flash, uncomment following pt entry
#[[pt_entry]]
#type = 8
#name = "rf_para"
#device = 0
#address0 = 0x1FF000
#size0 = 0x1000
#address1 = 0
#size1 = 0
## compressed image must set len,normal image can left it to 0
#len = 0
[[pt_entry]]
type = 0
name = "spiffs"
device = 0
address0 = 0x210000  ##给spiffs文件系统用,开始地址
size0 = 0x28000         ##给spiffs文件系统用,大小
address1 = 0x238000  ##给easyflash文件系统用,开始地址
size1 = 0x8000           ##给easyflash文件系统用,大小
len = 0
修改安信可已移植好的ef_port.c
* This file is part of the EasyFlash Library.
* Copyright (c) 2015, Armink, <armink.ztl@gmail.com>
* Permission is hereby granted, free of charge, to any person obtaining
* a copy of this software and associated documentation files (the
* 'Software'), to deal in the Software without restriction, including
* without limitation the rights to use, copy, modify, merge, publish,
* distribute, sublicense, and/or sell copies of the Software, and to
* permit persons to whom the Software is furnished to do so, subject to
* the following conditions:
* The above copyright notice and this permission notice shall be
* included in all copies or substantial portions of the Software.
* THE SOFTWARE IS PROVIDED 'AS IS', WITHOUT WARRANTY OF ANY KIND,
* EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF
* MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT.
* IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY
* CLAIM, DAMAGES OR OTHER LIABILITY, WHETHER IN AN ACTION OF CONTRACT,
* TORT OR OTHERWISE, ARISING FROM, OUT OF OR IN CONNECTION WITH THE
* SOFTWARE OR THE USE OR OTHER DEALINGS IN THE SOFTWARE.
* Function: Portable interface for each platform.
* Created on: 2015-01-16
#include <easyflash.h>
#include <stdarg.h>
#include <stdio.h>
#include <string.h>
#include <FreeRTOS.h>
#include <semphr.h>
#include <bl_mtd.h>
#include <ef_cfg.h>
#include <hosal_flash.h>
#include <hal_boot2.h>
uint32_t ENV_AREA_SIZE;
uint32_t SECTOR_NUM;
uint32_t EF_START_ADDR;
/* default environment variables set for user */
static const ef_env default_env_set[] = {
        {"boot_times", "3", 1}
static SemaphoreHandle_t env_cache_lock = NULL;
* Flash port for hardware initialize.
* @param default_env default ENV set for user
* @param default_env_size default ENV size
* @return result
EfErrCode ef_port_init(ef_env const **default_env, size_t *default_env_size)
    uint32_t addr0, addr1;
    uint32_t size0, size1;
    int active, ret;
    ret = hal_boot2_partition_addr("spiffs",&addr0,&addr1,&size0,&size1,&active);
    if (size1 < 8 * 1024) {
        //printf("[ERROR]psm partition is less than 8k,easyflash can not work!");
        return EF_ENV_INIT_FAILED;
    else{
        EF_START_ADDR = addr1;
        ENV_AREA_SIZE = (size1 / EF_ERASE_MIN_SIZE) * EF_ERASE_MIN_SIZE;
        SECTOR_NUM = ENV_AREA_SIZE / EF_ERASE_MIN_SIZE;
        //printf("ENV AREA SIZE %ld, SECTOR NUM %ld\r\n", ENV_AREA_SIZE, SECTOR_NUM);
        *default_env = default_env_set;
        *default_env_size = sizeof(default_env_set) / sizeof(default_env_set[0]);
        //printf("*default_env_size = 0x%08x\r\n", *default_env_size);
    #if configUSE_RECURSIVE_MUTEXES
        env_cache_lock = xSemaphoreCreateRecursiveMutex();
    #else
        env_cache_lock = xSemaphoreCreateMutex();
    #endif
        return EF_NO_ERR;
* Read data from flash.
* @note This operation's units is word.
* @param addr flash address
* @param buf buffer to store read data
* @param size read bytes size
* @return result
EfErrCode ef_port_read(uint32_t addr, uint32_t *buf, size_t size)
    EfErrCode result = EF_NO_ERR;
    if(hosal_flash_raw_read((uint32_t*)buf, addr, size) != 0){
        //printf("--------EF_READ_ERR--------");
        result = EF_READ_ERR;
    //printf("--------ef_port_read--------%ld;%lx;%d",*buf,addr,size);
    return result;
* Erase data on flash.
* @note This operation is irreversible.
* @note This operation's units is different which on many chips.
* @param size erase bytes size
* @return result
EfErrCode ef_port_erase(uint32_t addr, size_t size)
    /* make sure the start address is a multiple of EF_ERASE_MIN_SIZE */
    EF_ASSERT(addr % EF_ERASE_MIN_SIZE == 0);
    if(hosal_flash_raw_erase(addr, size) != 0){
        //printf("--------EF_ERASE_ERR--------");
        result = EF_ERASE_ERR;
    //printf("--------ef_port_erase--------%lx;%d",addr,size);
    return result;
* Write data to flash.
* @note This operation must after erase. @see flash_erase.
* @param buf the write data buffer
* @param size write bytes size
* @return result
EfErrCode ef_port_write(uint32_t addr, const uint32_t *buf, size_t size)
    if(hosal_flash_raw_write((const uint32_t*)buf, addr, size) != 0){
        //printf("--------EF_WRITE_ERR--------");
        result = EF_WRITE_ERR;
//printf("--------ef_port_write--------%ld;%lx;%d",*buf,addr,size);
    return result;
* lock the ENV ram cache
void ef_port_env_lock(void) {
    xSemaphoreTakeRecursive(env_cache_lock,
                 portMAX_DELAY);
#else
    /* You can add your code under here. */
    xSemaphoreTake( env_cache_lock,
                 portMAX_DELAY );
#endif
* unlock the ENV ram cache
void ef_port_env_unlock(void) {
    xSemaphoreGiveRecursive(env_cache_lock);
#else
    xSemaphoreGive( env_cache_lock );
#endif
extern void vprint(const char *fmt, va_list argp);
* This function is print flash debug info.
* @param file the file which has call this function
* @param line the line number which has call this function
* @param format output format
* @param ... args
void ef_log_debug(const char *file, const long line, const char *format, ...) {
#ifdef PRINT_DEBUG
    va_list args;
    /* args point to the first variable parameter */
    va_start(args, format);
    vprint(format, args);
    va_end(args);
#endif
* This function is print flash routine info.
* @param ... args
void ef_log_info(const char *format, ...) {
    va_list args;
    va_end(args);
* This function is print flash non-package info.
* @param ... args
void ef_print(const char *format, ...) {
    va_list args;
    va_end(args);
hal_boot2_partition_addr("spiffs",&addr0,&addr1,&size0,&size1,&active);这个函数可以得到分区文件partition_cfg_4M.toml的开始地址和大小。修改spiffs的起始地址和大小,cfg.phys_addr = addr0;cfg.phys_size = size0;spiffs文件系统就存在flash这个空间,烧写程序和OAT升级都不会破坏这个空间,也就是spiffs数据不会丢失。
else{
这个给easyflash使用。烧写程序和OAT升级都不会破坏这个空间,也就是easyflash 数据不会丢失。
上传的附件: 新建文件夹.rar (580.25 KB, 下载次数: 4)
2025-3-14 21:19:19
学习一下,虽然我没有wb2
2025-3-15 23:12:01
大佬 能不能 加点注释
2025-3-16 12:29:34
真不错,就是空闲时间太少了不方便玩。
2025-3-16 23:06:32
非常感谢分享,非常有用,都是实用东东。
  • 会员数: 29160 个
  • 话题数: 42024 篇
