【安信可小安派BW21-CBV-Kit】(二)DIY纸质出入记录器
BETCuser
小安派·BW21-CBV-KIt 996 4 2025-3-19 00:01:19
本次通过安信可小安派BW21-CBV-Kit+热敏打印模块开发一款纸质出入记录器。可以通过人脸识别确认出入人员,并实时对出入记录进行打印。
在淘宝选择了一款热敏打印模块,这里就不贴链接和店铺了,大家可以根据需求自行选配
根据热敏打印模块的官方说明,可使用TTL、RS232、USB三种模式进行连接。我选择的是TTL连接的BW21-CBV-Kit
根据安信可小安派BW21-CBV-Kit官方资料(https://fcniufr8ibx1.feishu.cn/wiki/RJ9pw7PsRieLu2k257FcO2hzn9b)
IOA2及IOA3对应UART1_TXD及UART1_RXD。用IOA2通过排线连接热敏打印模块RXD,IOA3通过排线连接热敏打印模块TXD,便完成了最基本的硬件连接连接。
以下为实物连接方式
为使安信可小安派BW21-CBV-Kit可以正常输出内容,需要初始化Serial1.begin(115200);同时当检测到人脸时Serial1.println(item.name());
完整代码如下:
 Example guide:
 https://www.amebaiot.com/en/amebapro2-arduino-neuralnework-face-recognition/
 Face registration commands
 Point the camera at a target face and enter the following commands into the serial monitor,
 Register face:                       "REG={Name}"  Ensure that there is only one face detected in frame
 Remove face:                         "DEL={Name}"  Remove a registered face
 Reset registered faces:              "RESET"       Forget all previously registered faces
 Backup registered faces to flash:    "BACKUP"      Save registered faces to flash
 Restore registered faces from flash: "RESTORE"     Load registered faces from flash
 NN Model Selection
 Select Neural Network(NN) task and models using modelSelect(nntask, objdetmodel, facedetmodel, facerecogmodel).
 Replace with NA_MODEL if they are not necessary for your selected NN Task.
 NN task
 OBJECT_DETECTION/ FACE_DETECTION/ FACE_RECOGNITION
 Models
 YOLOv3 model         DEFAULT_YOLOV3TINY   / CUSTOMIZED_YOLOV3TINY
 YOLOv4 model         DEFAULT_YOLOV4TINY   / CUSTOMIZED_YOLOV4TINY
 YOLOv7 model         DEFAULT_YOLOV7TINY   / CUSTOMIZED_YOLOV7TINY
 SCRFD model          DEFAULT_SCRFD        / CUSTOMIZED_SCRFD
 MobileFaceNet model  DEFAULT_MOBILEFACENET/ CUSTOMIZED_MOBILEFACENET
 No model             NA_MODEL
#include "WiFi.h"
#include "StreamIO.h"
#include "VideoStream.h"
#include "RTSP.h"
#include "NNFaceDetectionRecognition.h"
#define CHANNEL   0
#define CHANNELNN 3
// Customised resolution for NN
#define NNWIDTH  576
#define NNHEIGHT 320
VideoSetting config(VIDEO_FHD, 30, VIDEO_H264, 0);
NNFaceDetectionRecognition facerecog;
RTSP rtsp;
StreamIO videoStreamer(1, 1);
StreamIO videoStreamerFDFR(1, 1);
StreamIO videoStreamerRGBFD(1, 1);
char ssid[] = "SSID";    // your network SSID (name)
char pass[] = "password";        // your network password
int status = WL_IDLE_STATUS;
String Last = " ";
IPAddress ip;
int rtsp_portnum;
void setup()
    Serial.begin(115200);
    // Attempt to connect to Wifi network:
        //Serial.print("Attempting to connect to WPA SSID: ");
        //Serial.println(ssid);
        delay(2000);
    ip = WiFi.localIP();
    config.setBitrate(2 * 1024 * 1024);    // Recommend to use 2Mbps for RTSP streaming to prevent network congestion
    Camera.videoInit();
    rtsp.configVideo(config);
    rtsp.begin();
    // Configure Face Recognition model
    facerecog.configVideo(configNN);
    facerecog.modelSelect(FACE_RECOGNITION, NA_MODEL, DEFAULT_SCRFD, DEFAULT_MOBILEFACENET);
    facerecog.begin();
    facerecog.setResultCallback(FRPostProcess);
        //Serial.println("StreamIO link start failed");
    Camera.channelBegin(CHANNEL);
    videoStreamerRGBFD.registerInput(Camera.getStream(CHANNELNN));
    videoStreamerRGBFD.setStackSize();
    videoStreamerRGBFD.setTaskPriority();
    videoStreamerRGBFD.registerOutput(facerecog);
    if (videoStreamerRGBFD.begin() != 0) {
    // Start video channel for NN
    OSD.begin();
void loop()
    if (Serial.available() > 0) {
        String input = Serial.readString();
        input.trim();
        if (input.startsWith(String("REG="))) {
            String name = input.substring(4);
            facerecog.registerFace(name);
        } else if (input.startsWith(String("DEL="))) {
            facerecog.removeFace(name);
        } else if (input.startsWith(String("RESET"))) {
            facerecog.resetRegisteredFace();
        } else if (input.startsWith(String("BACKUP"))) {
            facerecog.backupRegisteredFace();
        } else if (input.startsWith(String("RESTORE"))) {
            facerecog.restoreRegisteredFace();
    delay(2000);
    OSD.createBitmap(CHANNEL);
    OSD.update(CHANNEL);
// User callback function for post processing of face recognition results
void FRPostProcess(std::vector<FaceRecognitionResult> results)
    //Serial.print("Network URL for RTSP Streaming: ");
    //Serial.print("rtsp://");
    //Serial.print(ip);
    //Serial.print(":");
    //Serial.println(rtsp_portnum);
    //Serial.println(" ");
    //printf("Total number of faces detected = %d\r\n", facerecog.getResultCount());
    if (facerecog.getResultCount() > 0) {
        for (int i = 0; i < facerecog.getResultCount(); i++) {
            FaceRecognitionResult item = results[i];
            uint32_t osd_color;
            if (String(item.name()) == String("unknown")) {
                osd_color = OSD_COLOR_RED;
                //Serial1.println("unknownuser");
            } else {
                osd_color = OSD_COLOR_GREEN;
                if(Last!=String(item.name()))
            // Draw boundary box
            //printf("Face %d name %s:\t%d %d %d %d\n\r", i, item.name(), xmin, xmax, ymin, ymax);
            //printf("%s",item.name());
            OSD.drawRect(CHANNEL, xmin, ymin, xmax, ymax, 3, osd_color);
            char text_str[40];
            //snprintf(text_str, sizeof(text_str), "Face:%s", item.name());
            OSD.drawText(CHANNEL, xmin, ymin - OSD.getTextHeight(CHANNEL), text_str, osd_color);
则此时,当安信可小安派BW21-CBV-Kit检测到注册人脸时,则可在热敏打印模块输出对应人脸名称,以此达到纸质出入记录的效果
这个感觉可以用在出入库
哇很棒~
佬,赞
2025-3-19 15:36:30
这个热敏模块号,直接输出就行,都不用pos指令。另外多人的时候,这个应该会丢人……就是有人检测到了但记录不下来
  • 会员数: 30676 个
  • 话题数: 44748 篇
