【PB-03F-kit】下载SDK+点灯+烧录(小白向)
成为嵌入式高手
高级会员
高级会员
PB&TG系列 1762 6 2024-12-2 20:21:55
[i=s] 本帖最后由 成为嵌入式高手 于 2024-12-3 10:26 编辑 [/i]<br /> <br />
大家好,我是成为嵌入式高手(bushi),时隔这么久,我又来发帖了[笑哭][笑哭][笑哭]。非常感谢安信可科技!!!!此教程如存在任何不正确的地方,欢迎各位大佬指出[抱拳]
【PB-03F-kit】下载SDK+烧录+点灯(小白向)
园长在中奖帖里也有一些参考帖。
【中奖通知】申请PB-03F开发板的同学看过来! - 活动版块 - 物联网开发者社区-安信可论坛 - Powered by Discuz!
今天给大家带来的是PB-03F-Kit的SDK下载、将程序烧录到开发板和点亮一个RGB灯。
1.准备工作
PB-03F-kit 开发板,MicroUSB数据线一根(我用的是之前电赛TI的数据线)
开发板的正反面
2.下载SDK(前提电脑安装有Keil)
首先来到安信可论坛首页,点击开发资料
屏幕截图2024-12-02191112.png 然后点击 蓝牙模组系列 ----> 奉加PB/TG系列 屏幕截图2024-12-02191416.png 接着下滑找到如图所示的 3.2 PB-03系列模组应用开发资料 屏幕截图2024-12-02191723.png
下载箭头所指的两个压缩包即可(Tip)
image.png phypluskit_v2.5.2b 为烧录工具 phy6222_v313_0512 为SDK
3.打开并修改示例工程
找到SDK文件下的GPIO工程,文件路径如图所示。 D:\Download\phy6222_v313_0512\example\peripheral\gpio image.png 然后,双击 gpio.uvprojx Keil工程 打开app文件下的 gpio_demo.c文件 image.png 将原来 void Key_Demo_Init(uint8 task_id) 函数里面所有代码注释掉或者删除。 添加以下的代码
void
key_TaskID = task_id;// 任务id,不用管
hal_gpio_write(GPIO_P18,HAL_HIGH_IDLE); // GPIO18 输出高电平,点亮LED
修改后的demo.c 的全部代码为:
    Phyplus Microelectronics Limited confidential and proprietary.
    All rights reserved.
    IMPORTANT: All rights of this software belong to Phyplus Microelectronics
    Limited ("Phyplus"). Your use of this Software is limited to those
    specific rights granted under  the terms of the business contract, the
    confidential agreement, the non-disclosure agreement and any other forms
    of agreements as a customer or a partner of Phyplus. You may not use this
    Software unless you agree to abide by the terms of these agreements.
    You acknowledge that the Software may not be modified, copied,
    distributed or disclosed unless embedded on a Phyplus Bluetooth Low Energy
    (BLE) integrated circuit, either as a product or is integrated into your
    products.  Other than for the aforementioned purposes, you may not use,
    reproduce, copy, prepare derivative works of, modify, distribute, perform,
    display or sell this Software and/or its documentation for any purposes.
    YOU FURTHER ACKNOWLEDGE AND AGREE THAT THE SOFTWARE AND DOCUMENTATION ARE
    PROVIDED AS IS WITHOUT WARRANTY OF ANY KIND, EITHER EXPRESS OR IMPLIED,
    INCLUDING WITHOUT LIMITATION, ANY WARRANTY OF MERCHANTABILITY, TITLE,
    NON-INFRINGEMENT AND FITNESS FOR A PARTICULAR PURPOSE. IN NO EVENT SHALL
    PHYPLUS OR ITS SUBSIDIARIES BE LIABLE OR OBLIGATED UNDER CONTRACT,
    NEGLIGENCE, STRICT LIABILITY, CONTRIBUTION, BREACH OF WARRANTY, OR OTHER
    LEGAL EQUITABLE THEORY ANY DIRECT OR INDIRECT DAMAGES OR EXPENSES
    INCLUDING BUT NOT LIMITED TO ANY INCIDENTAL, SPECIAL, INDIRECT, PUNITIVE
    OR CONSEQUENTIAL DAMAGES, LOST PROFITS OR LOST DATA, COST OF PROCUREMENT
    OF SUBSTITUTE GOODS, TECHNOLOGY, SERVICES, OR ANY CLAIMS BY THIRD PARTIES
    (INCLUDING BUT NOT LIMITED TO ANY DEFENSE THEREOF), OR OTHER SIMILAR COSTS.
    Filename:       gpio_demo.c
    Revised:        $Date $
    Revision:       $Revision $
    INCLUDES
#include "OSAL.h"
#include "gpio_demo.h"
#include "log.h"
#include "gpio.h"
#include "clock.h"
#include "pwrmgr.h"
#include "error.h"
#include "key.h"
    pulseMeasure_Task
    Task pulseMeasure sample code,we can use p04~p07 and p11~p15 easily.
static uint8 pulseMeasure_TaskID;
typedef struct
    bool          enable;
    bool          pinstate;
    uint32_t      edge_tick;
} gpioin_Trig_t;
typedef struct
    GPIO_Pin_e    pin;
    bool          type;
    uint32_t      ticks;
} gpioin_pulse_Width_measure_t;
gpioin_pulse_Width_measure_t measureResult =
    .pin = GPIO_P14,
static gpioin_Trig_t gpioTrig =
    .enable = FALSE,
    .edge_tick = 0,
void plus_edge_callback(void)
    LOG("pulse:%d %d\n",measureResult.type,measureResult.ticks);
void pulse_measure_callback(GPIO_Pin_e pin,IO_Wakeup_Pol_e type)
    if(gpioTrig.enable == FALSE)
        gpioTrig.enable = TRUE;
        gpioTrig.edge_tick = hal_systick();
        return;
    measureResult.type = type;
    measureResult.ticks = hal_ms_intv(gpioTrig.edge_tick);
    plus_edge_callback();
void Pulse_Measure_Init( uint8 task_id )
    pulseMeasure_TaskID = task_id;
    hal_gpio_init();
    hal_gpioin_register(measureResult.pin,pulse_measure_callback,pulse_measure_callback);
    gpioTrig.pinstate = hal_gpio_read(measureResult.pin);
uint16 Pulse_Measure_ProcessEvent( uint8 task_id, uint16 events )
    if(task_id != pulseMeasure_TaskID)
        return 0;
    // Discard unknown events
    return 0;
    gpio_wakeup_Task
    Task gpio wakeup sample code
    The followinng code shows P14 wakeup the system when there is a posedge or negedge.
static uint8 gpio_wakeup_TaskID;
void posedge_callback_wakeup(GPIO_Pin_e pin,IO_Wakeup_Pol_e type)
    if(type == POSEDGE)
        LOG("wakeup(pos):gpio:%d type:%d\n",pin,type);
    else
        LOG("error\n");
void negedge_callback_wakeup(GPIO_Pin_e pin,IO_Wakeup_Pol_e type)
    if(type == NEGEDGE)
        LOG("wakeup(neg):gpio:%d type:%d\n",pin,type);
    else
     P00~P03:default jtag,we can use it as wakeup pin when no debug.
     P04~P07,P11~P15,P18~P30:default gpio,use it easily.
     P08:mode select pin,cannot used as other usage.
     P09~P10,it is uart in burn mode which cannot config.it is configable when in debug mode.
     P16~P17:xtal pin,when use this pins,please use rc as system frequency.config hal_rtc_clock_config(CLK_32K_RCOSC) in hal_init first.
     P31~P34:default spif,we can use it as wakeup pin directly,we driver have completed its multiplex config.
typedef struct gpioin_wakeup_t
    GPIO_Pin_e pin;
    gpioin_Hdl_t posedgeHdl;
    gpioin_Hdl_t negedgeHdl;
} gpioin_wakeup;
gpioin_wakeup gpiodemo[GPIO_WAKEUP_PIN_NUM] =
    GPIO_P14,posedge_callback_wakeup,negedge_callback_wakeup,
    GPIO_P23,posedge_callback_wakeup,negedge_callback_wakeup,
    GPIO_P31,posedge_callback_wakeup,negedge_callback_wakeup,
void GPIO_Wakeup_Init(uint8 task_id )
    uint8_t i = 0;
    static bool gpioin_state[GPIO_WAKEUP_PIN_NUM];
    hal_gpio_init();
    gpio_wakeup_TaskID = task_id;
    LOG("gpio wakeup demo start...\n");
    //hal_gpio_pull_set(P14,WEAK_PULL_UP);
    for(i = 0; i<GPIO_WAKEUP_PIN_NUM; i++)
        hal_gpioin_register(gpiodemo[i].pin,gpiodemo[i].posedgeHdl,gpiodemo[i].negedgeHdl);
        gpioin_state[i] = hal_gpio_read(gpiodemo[i].pin);
        LOG("gpioin_state:%d %d\n",i,gpioin_state[i]);
uint16 GPIO_Wakeup_ProcessEvent( uint8 task_id, uint16 events )
    if(task_id != gpio_wakeup_TaskID)
        return 0;
    return 0;
    key_Task:gpio config as key
static uint8 key_TaskID;
#define KEY_DEMO_ONCE_TIMER      0x0001
#define KEY_DEMO_CYCLE_TIMER     0x0002
//#define HAL_KEY_EVENT          0x0100//assign short key event in your app event process
#ifdef HAL_KEY_SUPPORT_LONG_PRESS
    //    #define KEY_DEMO_LONG_PRESS_EVT   0x0200 //if use long key,assign long key event in your app process
#endif
static void key_press_evt(uint8_t i,key_evt_t key_evt)
    LOG("\nkey index:%d gpio:%d ",i,key_state.key[i].pin);
    switch(key_evt)
    case HAL_KEY_EVT_PRESS:
        LOG("key(press down)\n");
        break;
    case HAL_KEY_EVT_RELEASE:
        LOG("key(press release)\n");
        break;
    case HAL_KEY_EVT_LONG_RELEASE:
        hal_pwrmgr_unlock(MOD_USR1);
        LOG("key(long press release)\n");
        break;
        #endif
    default:
        LOG("unexpect\n");
        break;
static void P16_wakeup_handler(void)
    hal_gpio_cfg_analog_io(P16,Bit_DISABLE);
static void P17_wakeup_handler(void)
    hal_gpio_cfg_analog_io(P17,Bit_DISABLE);
typedef struct _uart_Context
    bool        enable;
    uint8_t     tx_state;
    uart_Tx_Buf_t tx_buf;
    uart_Cfg_t  cfg;
} uart_Ctx_t;
//extern uart_Ctx_t m_uartCtx;
void uart_port_reconfig(void)
    uart_Cfg_t cfg_user =
        .tx_pin = P14,
        .rx_pin = P15,
        .rts_pin = GPIO_DUMMY,
        .cts_pin = GPIO_DUMMY,
        .baudrate = 115200,
        .use_fifo = TRUE,
        .hw_fwctrl = FALSE,
        .use_tx_buf = FALSE,
        .parity     = FALSE,
        .evt_handler = NULL,
    hal_gpio_fmux(P9,Bit_DISABLE);
    hal_gpio_fmux(P10,Bit_DISABLE);
    hal_gpio_pin_init(P14,OEN);
    hal_gpio_pin_init(P15,IE);
    //m_uartCtx.enable = FALSE;
    hal_uart_init(cfg_user,UART0);//uart init
    LOG("uart new port...\n");
    key_TaskID = task_id;// ??id,???????
    // ?????????hal_gpio_pin_init(pin,GPIO_OUTPUT);
    hal_gpio_write(GPIO_P18,HAL_HIGH_IDLE); // GPIO18 ?????,??LED
//void Key_Demo_Init(uint8 task_id)
//    uint8_t i = 0;
//    key_TaskID = task_id;
//    LOG("gpio key demo start...\n");
//    hal_gpio_init();
//    hal_gpioretention_register(P20);
//    hal_gpio_write(P20,1);
////    hal_gpio_pin2pin3_control(P2,1);
//        when use key,please set the following parameters:
//        1.key number,config KEY_NUM in key.h
//        2.gpio used,config key_state.pin
//             P00~P03:default jtag,we can use it as key when no debug.
//             P04~P07,P11~P15:default gpio,use it easily.
//             P08:mode select pin,cannot used as other usage.
//             P09~P10,it is uart in burn mode which cannot config.it is configable when in debug mode.
//             P16~P17:xtal pin,when use this pins,please use rc as system frequency.config hal_rtc_clock_config(CLK_32K_RCOSC) in hal_init first.
//             P18~P34:wakeup is supported,but interrupt is not supported,so config it as key is not suggested.
//        3.idle level,config key_state.idle_level
//        4.key type,if only use press and release,ignore the long press and release code
//        5.taskID and callback function
////  key_state.key[0].pin = GPIO_P14;//default gpio
////  key_state.key[1].pin = GPIO_P15;
////  key_state.key[2].pin = GPIO_P00;//default jtag
////  key_state.key[3].pin = GPIO_P01;
////  key_state.key[4].pin = GPIO_P02;
////  key_state.key[5].pin = GPIO_P03;
////  key_state.key[6].pin = GPIO_P16;//default xtal
////  key_state.key[7].pin = GPIO_P17;//default xtal
////  key_state.key[0].pin = GPIO_P09;
////  key_state.key[1].pin = GPIO_P10;
//    key_state.key[0].pin = GPIO_P03;
//    for(i = 0; i < HAL_KEY_NUM; ++i)
//        key_state.key[i].state = HAL_STATE_KEY_IDLE;
//        key_state.key[i].idle_level = HAL_LOW_IDLE;
//        if(key_state.key[i].pin == GPIO_P16)
//            hal_pwrmgr_register(MOD_USR2,NULL,P16_wakeup_handler);
//            hal_gpio_cfg_analog_io(key_state.key[i].pin,Bit_DISABLE);
//            LOG("P16 is used\n");
//        else if(key_state.key[i].pin == GPIO_P17)
//            hal_pwrmgr_register(MOD_USR3,NULL,P17_wakeup_handler);
//            LOG("P17 is used\n");
//        else if((key_state.key[i].pin == GPIO_P09) || (key_state.key[i].pin == GPIO_P10))
//            uart_port_reconfig();
////  key_state.key[0].idle_level = HAL_LOW_IDLE;
////  key_state.key[1].idle_level = HAL_HIGH_IDLE;
//    key_state.task_id = key_TaskID;
//    key_state.key_callbank = key_press_evt;
//    key_init();
//    osal_start_timerEx(key_TaskID, KEY_DEMO_ONCE_TIMER, 5000);
//    osal_start_reload_timer(key_TaskID, KEY_DEMO_CYCLE_TIMER, 5000);
uint16 Key_ProcessEvent( uint8 task_id, uint16 events )
    if(task_id != key_TaskID)
        return 0;
    if( events & KEY_DEMO_ONCE_TIMER)
        //LOG("once timer\n");
        osal_start_timerEx( key_TaskID, KEY_DEMO_ONCE_TIMER, 5000);
        return (events ^ KEY_DEMO_ONCE_TIMER);
    if( events & KEY_DEMO_CYCLE_TIMER)
        //LOG("recycle timer\n");
        return (events ^ KEY_DEMO_CYCLE_TIMER);
    if( events & HAL_KEY_EVENT)                                                     //do not modify,key will use it
        for (uint8 i = 0; i < HAL_KEY_NUM; ++i)
            if ((key_state.temp[i].in_enable == TRUE)||
                    (key_state.key[i].state == HAL_STATE_KEY_RELEASE_DEBOUNCE))
                gpio_key_timer_handler(i);
        return (events ^ HAL_KEY_EVENT);
    if( events & KEY_DEMO_LONG_PRESS_EVT)
        for (int i = 0; i < HAL_KEY_NUM; ++i)
            if(key_state.key[i].state == HAL_KEY_EVT_PRESS)
                LOG("key:%d gpio:%d ",i,key_state.key[i].pin);
                LOG("key(long press down)");
                //user app code long press down process
        return (events ^ KEY_DEMO_LONG_PRESS_EVT);
    #endif
    return 0;
最后一步的前一步
打开魔术棒,点击C/C++,将 CFG_SLEEP_MODE=PWR_MODE_SLEEP 修改为 CFG_SLEEP_MODE=PWR_MODE_NO_SLEEP。其目的是是开发板不会处于低功耗模式。 屏幕截图2024-12-02194536.png
最后一步
点击编译即可 image.png 会出现3个警告,但在我们点灯的路上不影响!!!! image.png 勾选HEX文件,会在bin文件夹下创建编译成功的hex文件。通过烧录软件烧录进去即可 image.png 在此路径下可以找到我们刚刚生成的HEX文件,记住此路径 image.png
5.烧录
双击PhyPlusKit.exe,运行,将开发板连接到电脑。查看开发板的COM。 image.png 此开发板的波特率为115200,如果将波特率调为UXTDWU,串口会打印出如下信息。 image.png
敲黑板,此时,按住开发板的复位键一会,松开,出现
image.png 即可。波特率会自动切换到115200 1.首先擦除开发板里内容 2.双击APP,将刚才bin文件下的hex文件导入,最后点击wrtie写入即可 屏幕截图2024-12-02200142.png
烧录成功如图所示,将开发板与电脑重新连接电脑即可看见RGB灯已经亮起
如果出现以下报错信息
点击disconnect----->将波特率调回UXTDWU------>点击connect----->按住RESET一会,出现cmd------>再Erase(擦除)----->再(写入)write一遍就行了 屏幕截图2024-12-02200528.png
点亮效果
视频连接
先挖坑,明天早上来填坑(已填坑)
2024.12.02
【[PB-03F]下载SDK+编译+点灯】https://www.bilibili.com/video/BV1Q7zyY2Eg9?vd_source=8c1cff176f80c1bb4d19a3bb6cfbefc2 2024.12.03
2024-12-2 21:50:18
不错不错
2024-12-3 07:48:33
学习了,
2024-12-3 08:36:17
写的不错,加上视频后,给你加个精华~
2024-12-3 10:27:02
爱笑 发表于 2024-12-3 08:36
写的不错,加上视频后,给你加个精华~
已经填坑了
2024-12-4 09:23:25
写的很好,准备跟着玩。
2024-12-10 18:34:57
  • 会员数: 29185 个
  • 话题数: 42068 篇
