esp8266连接阿里云平台
caracal
新手上路
新手上路
ESP8266系列 1635 5 2024-10-26 12:29:25
麻烦问一下,esp8266nodemcu在使用arduino.ide连接阿里云平台的时候,wifi配置正常但连接不上mqtt,显示报错如下:
Attempting MQTT connection...failed, rc=-4 try again in 5 seconds
以下附报错源代码:
#include <ESP8266WiFi.h>
#include <PubSubClient.h>
// WiFi 配置
const char* ssid = "Flutter";        // 替换为你的热点SSID
const char* password = "87654321";   // 替换为你的热点密码
// 阿里云 IoT 配置
const char* productKey = "";       // 替换为你的产品密钥
const char* deviceName = "";             // 替换为你的设备名称
const char* deviceSecret = "";   // 替换为你的设备密钥
// MQTT 服务器配置
const char* mqttServer = "iot-as-mqtt.cn-shanghai.aliyuncs.com";
const int mqttPort = 1883;
WiFiClient espClient;
PubSubClient client(espClient);
void setup() {
    Serial.begin(115200);
    setup_wifi();
    client.setServer(mqttServer, mqttPort);
    client.setCallback(mqttCallback);
void setup_wifi() {
    Serial.print("Connecting to WiFi...");
    WiFi.begin(ssid, password);
    int attempts = 0;
    while (WiFi.status() != WL_CONNECTED) {
        delay(500);
        Serial.print(".");
        attempts++;
        if (attempts >= 20) {
            Serial.println(" Failed to connect to WiFi.");
            Serial.print("WiFi status: ");
            Serial.println(WiFi.status());
            return;
    Serial.println(" WiFi connected");
void mqttCallback(char* topic, byte* payload, unsigned int length) {
    Serial.print("Message arrived [");
    Serial.print(topic);
    Serial.print("]: ");
    for (int i = 0; i < length; i++) {
        Serial.print((char)payload[i]);
    Serial.println();
void connectMQTT() {
    while (!client.connected()) {
        Serial.print("Attempting MQTT connection...");
        String clientId = String(productKey) + "." + String(deviceName); // 客户端ID
        if (client.connect(clientId.c_str(), deviceName, deviceSecret)) {
            Serial.println("MQTT connected");
        } else {
            Serial.print("failed, rc=");
            Serial.print(client.state()); // 打印错误代码
            Serial.println(" try again in 5 seconds");
            delay(5000);
void loop() {
    if (!client.connected()) {
        connectMQTT();
    client.loop();
    // 示例:发送数据到阿里云
    String payload = "{\"id\":\"1\",\"data\":{\"temperature\":25}}"; // 示例数据
    String topic = "/sys/" + String(productKey) + "/" + String(deviceName) + "/thing/event/property/post"; // 主题
    if (client.publish(topic.c_str(), payload.c_str())) {
        Serial.println("Data sent to Aliyun: " + payload);
    } else {
        Serial.println("Data failed to send to Aliyun");
    delay(10000); // 每10秒发送一次数据
2024-10-28 08:50:00
arduino开发的,可以去相关社区找找资料哈。
2024-10-28 10:22:13
感谢回帖,但是我们是在全网查找资料无果以后才来论坛问的,阿里云那边的工程师也给不出好的解释,连接他们的服务器超时这个问题太难解释了
2024-10-28 14:35:59
  1. // Possible values for client.state()
  2. #define MQTT_CONNECTION_TIMEOUT     -4
  3. #define MQTT_CONNECTION_LOST        -3
  4. #define MQTT_CONNECT_FAILED         -2
  5. #define MQTT_DISCONNECTED           -1
  6. #define MQTT_CONNECTED               0
  7. #define MQTT_CONNECT_BAD_PROTOCOL    1
  8. #define MQTT_CONNECT_BAD_CLIENT_ID   2
  9. #define MQTT_CONNECT_UNAVAILABLE     3
  10. #define MQTT_CONNECT_BAD_CREDENTIALS 4
  11. #define MQTT_CONNECT_UNAUTHORIZED    5
https://github.com/knolleary/pubsubclient/issues/159这个到这个库的issue里面就有回答
yyg
2024-11-1 13:03:04
去github找找,应该有,找对应的库
2025-6-4 09:42:58
我要学习一下
  • 会员数: 29760 个
  • 话题数: 43317 篇
