Ai+WB2-07S运用AT+HTTPCLIENTLINE访问网址显示96错误,且WiFi经常断开已解决
查看747 | 回复13 | 2024-10-7 16:45:51 | 显示全部楼层 |阅读模式
捕获1.PNG 捕获3.PNG 捕获4.PNG 捕获.PNG 且获取不了IP地址
[2024_10_07_15_59_31.377] send:AT+STAINFO?
[2024_10_07_15_59_31.387] recv:AT+STAINFO?
+STAINFO:2
SSID:
[2024_10_07_15_59_31.396] recv:RPI4
Password:rd12345678
dc:a6:32:bb:bf:b2,WPA2 TKIP,a8:17:10:61:9c:15,1,192.168.110.168,192.1
[2024_10_07_15_59_31.403] recv:68.110.2
OK
[2024_10_07_16_01_08.928] recv:AT+HTTPCLIENTLINE=1,2,,192.168.110.162,3000,
[2024_10_07_16_01_08.935] recv:
AT+HTTPCLIENTLINE:96
+ERROR
WiFi经常断开
[2024_10_07_16_30_23.209] recv:
+EVENT:WIFI_DISCONNECT
[2024_10_07_16_30_28.583] recv:
+EVENT:WIFI_CONNECT
[2024_10_07_16_30_43.601] recv:
[2024_10_07_16_30_48.994] recv:
+EVENT:WIFI_CONNECT
C:\Users\36875\Pictures\Saved Pictures
bzhou830 | 2024-10-7 20:06:50 | 显示全部楼层
图挂了
爱笑 | 2024-10-8 08:39:32 | 显示全部楼层
DFj | 2024-10-8 09:01:08 | 显示全部楼层
放了出现错误的 图片和相关的at指令
Ai-Thinker小泽 | 2024-10-8 09:20:23 | 显示全部楼层
啥固件版本
DFj | 2024-10-8 09:31:32 | 显示全部楼层
[2024_10_08_09_29_34.078] recv:AT+GMR
at version:V4.18_P3.0.0
[2024_10_08_09_29_34.087] recv:
sdk version:release_bl_iot_sdk_1.6.40
firmware version:release/V4.18_P23.1.0
DFj | 2024-10-8 09:41:34 | 显示全部楼层
应该是2328
123456 | 2024-10-8 10:40:38 | 显示全部楼层
检查下你路由器的加密方式是否为WPA/WPA2  目前该固件不支持WPA3模式
DFj | 2024-10-8 10:55:38 | 显示全部楼层
路由器加密方式是WPA/WPA2
123456 | 2024-10-8 11:13:28 | 显示全部楼层
DFj 发表于 2024-10-8 10:55
路由器加密方式是WPA/WPA2
给个实物接线图 还有看一下天线是否有接上
