小安派r2烧录问题
查看173 | 回复7 | 2024-9-20 13:14:19 | 显示全部楼层 |阅读模式
烧录时出现以下问题:
[13:05:57.751] - ========= get_boot_info =========
[13:05:57.752] - ========= image get bootinfo =========
[13:05:57.917] - Please Press Reset Key!
[13:06:05.375] - default set DTR high
[13:06:05.476] - clean buf
[13:06:05.503] - send sync
[13:06:05.719] - ack is b'4f4b'
[13:06:05.764] - shake hand success
[13:06:10.289] - Read data error,maybe not get excepted length
[13:06:10.289] - result: Read data error,maybe not get excepted length
[13:06:10.289] - get_boot_info no ok
[13:06:10.290] - ========= ChipID:  =========
[13:06:10.290] - Get bootinfo time cost(ms): 12537.638916015625
[13:06:10.291] - change bdrate: 2000000
[13:06:10.291] - Clock PLL set
[13:06:12.306] - ack is b''
[13:06:12.306] - Retry
[13:06:14.309] - ack is b''
[13:06:14.309] - Retry
[13:06:16.309] - ack is b''
[13:06:16.309] - Retry
[13:06:18.312] - ack is b''
[13:06:18.312] - {"ErrorCode": "000C","ErrorMsg":"BFLB SET CLOCK PLL FAIL"}
[13:06:18.312] - pll set fail!!
[13:06:18.380] - Burn Retry
[13:06:18.380] - Burn return with retry fail
(base) PS D:\code\anpi\AiPi-Open-Kits\AiPi-Eyes_weather>
请各位大佬指点
爱笑 | 2024-9-20 13:37:50 | 显示全部楼层
马上抓个技术来给你解决!
Ai-Thinker小泽 | 2024-9-20 13:43:05 | 显示全部楼层
降波特率
patrick00017 | 2024-9-20 14:08:55 | 显示全部楼层
解决了!
陈世繁华 | 2024-9-22 13:10:36 | 显示全部楼层
patrick00017 | 2024-9-23 15:40:46 | 显示全部楼层
陈世繁华 发表于 2024-9-22 13:10
请问一下是怎么解决的?是更改这些东西吗?我更改后测试还是不行
在aithinker-sdk文件夹下project.build文件中更改变量BAUDRATE,可以在那个文件中搜索
陈世繁华 | 2024-9-23 19:52:41 | 显示全部楼层
patrick00017 发表于 2024-9-23 15:40
在aithinker-sdk文件夹下project.build文件中更改变量BAUDRATE,可以在那个文件中搜索 ...
我这个图片中左边这些还需要更改吗?
陈世繁华 | 2024-9-23 20:06:02 | 显示全部楼层
非常感谢,已经烧录成功了
