【雷达灯控】安信可 Rd-03E + Ai-M61-32S-Kit+台灯照明
wuboy19
高级会员
高级会员
雷达灯控教程 2662 12 2024-3-25 00:23:06
引言
首先非常感谢安信可,园长,在免费申请Rd-03E模块时候多给了几个名额,当然很幸运的里面有我,在学校已经实现了所要求的功能,本文章主要是利用Ai-M61-32S-Kit开发板,实现了对Rd-03E距离和是否有人移动,直观效果就是人做面前灯一直亮着,人走后台灯熄灭,之前一直用充电宝加上usb小夜灯照明,所以这次就是即实现了要求,又可以应用于日常生活。
具体实施
开发环境
Clion加上博流sdk
目录结构如下
硬件及实物图:
usb夜灯用了nmos驱动
具体代码
#include "bflb_mtimer.h"
#include "bflb_uart.h"
#include "board.h"
#include "bflb_gpio.h"
#include "bflb_pwm_v2.h"
#include "bflb_clock.h"
#include <string.h>
#include <stdio.h>
void gpio_init();
void UART1_gpio_init();
void UART1_Init();
void led_fanzhuang();
void PWM_SG90();
struct bflb_device_s *pwm;
struct bflb_device_s *uart1_structure;
struct bflb_device_s *gpio;
static volatile uint8_t tx_end_flag = 0;
int sg90_pwm=0;
//static uint8_t uart_txbuf[128] = { 0 };
uint8_t data_count = 0;
uint8_t i_data = 0;
uint8_t distance;
char uart_rxbuf[1024] = {0};
char *uart_rx_wxw=NULL;
void uart_isr(int irq, void *arg)
    uint32_t intstatus = bflb_uart_get_intstatus(uart1_structure);
    if (intstatus & UART_INTSTS_RX_FIFO) {
        while (bflb_uart_rxavailable(uart1_structure)) {
            uart_rxbuf[data_count++] = bflb_uart_getchar(uart1_structure);
    if (intstatus & UART_INTSTS_RTO) {
        bflb_uart_int_clear(uart1_structure, UART_INTCLR_RTO);
        for(i_data=data_count;uart_rxbuf[i_data]!='\0';i_data++)
            uart_rxbuf[i_data]='\0';
        uart_rx_wxw=uart_rxbuf;
        data_count=0;
int main(void)
    board_init();
    gpio_init();
    UART1_Init();
//    PWM_SG90();
    while (1)
        if(uart_rx_wxw!=NULL)
            if((*(uart_rx_wxw)==0XAA)&&(*(uart_rx_wxw+1)==0XAA)&&(*(uart_rx_wxw+5)==0X55)&&(*(uart_rx_wxw+6)==0X55))
                distance=*(uart_rx_wxw+4)<<8|*(uart_rx_wxw+3);
                if(distance<100)
                    if((*(uart_rx_wxw+2)==0x01)||(*(uart_rx_wxw+2)==0x02))
                    else
                else
                printf("%d %d\n",*(uart_rx_wxw+2),distance);
            uart_rx_wxw=NULL;
        bflb_mtimer_delay_ms(50);
//        led_fanzhuang();
void gpio_init()
    printf("gpio output\r\n");//12为板载
//    bflb_gpio_init(gpio, GPIO_PIN_12, GPIO_OUTPUT | GPIO_INPUT | GPIO_PULLUP | GPIO_SMT_EN | GPIO_DRV_0);
    bflb_gpio_init(gpio, GPIO_PIN_14, GPIO_OUTPUT | GPIO_INPUT | GPIO_PULLUP | GPIO_SMT_EN | GPIO_DRV_0);
    struct bflb_device_s *gpio_uart1;
    gpio_uart1 = bflb_device_get_by_name("gpio");
    bflb_gpio_uart_init(gpio_uart1, GPIO_PIN_23, GPIO_UART_FUNC_UART1_TX);
    bflb_gpio_uart_init(gpio_uart1, GPIO_PIN_24, GPIO_UART_FUNC_UART1_RX);
void UART1_Init()
    UART1_gpio_init();
    uart1_structure = bflb_device_get_by_name("uart1");
    struct bflb_uart_config_s cfg;
    cfg.baudrate = 256000;
    cfg.data_bits = UART_DATA_BITS_8;
    cfg.stop_bits = UART_STOP_BITS_1;
    cfg.parity = UART_PARITY_NONE;
    cfg.flow_ctrl = 0;
    cfg.tx_fifo_threshold = 0;
    cfg.rx_fifo_threshold = 0;
    bflb_uart_init(uart1_structure, &cfg);
    bflb_uart_txint_mask(uart1_structure, true);
    bflb_uart_rxint_mask(uart1_structure, false);
//    bflb_uart_feature_control(uart1_structure, UART_CMD_SET_TX_FREERUN, false);
//    bflb_uart_feature_control(uart1_structure, UART_CMD_SET_TX_END_INTERRUPT, true);
    bflb_irq_attach(uart1_structure->irq_num, uart_isr, NULL);
    bflb_irq_enable(uart1_structure->irq_num);
    static int a=0;
    if(a==2)
        a=0;
    if(a%2==0)
        bflb_gpio_set(gpio, GPIO_PIN_12);
    else
    a++;
void PWM_SG90()
    struct bflb_device_s *gpio_PWM;
    gpio_PWM = bflb_device_get_by_name("gpio");
    bflb_gpio_init(gpio_PWM, GPIO_PIN_25, GPIO_FUNC_PWM0 | GPIO_ALTERNATE | GPIO_PULLUP | GPIO_SMT_EN | GPIO_DRV_1);
    pwm = bflb_device_get_by_name("pwm_v2_0");
            .clk_source = BFLB_SYSTEM_PBCLK,
            .clk_div = 800,
            .period = 2000,
    bflb_pwm_v2_init(pwm, &cfg);
//    bflb_pwm_v2_channel_set_threshold(pwm, PWM_CH0, 0, 500); /* duty = (500-100)/1000 = 40% */
//    bflb_pwm_v2_channel_set_threshold(pwm, PWM_CH1, 0, 25); /* duty = (400-200)/1000 = 20% */
//    bflb_pwm_v2_channel_positive_start(pwm, PWM_CH1);
//    bflb_pwm_v2_start(pwm);
实现视频
致谢
感谢WT_0213作者的烧录固件,还有一位作者,那个烧录固件不需要一直接着,上前前短接就行,感谢安信可,感谢院长。
工程文件
链接:https://pan.baidu.com/s/15RalmrUTGXnxtb9mI3W27A
提取码:8lk8
不错不错!
太强了啦
2024-3-25 10:55:29
赞,真不错。
2024-3-25 10:55:55
2024-3-25 11:06:25
小灯非常漂亮
2024-3-25 15:59:15
2024-3-25 16:00:21
谢谢,您的博客给我帮助很大,烧录精确测距固件很直接
赞一下
  • 会员数: 30894 个
  • 话题数: 44866 篇
