Ra-08(H) Minimum set of "AT" Commands to send and receive a message
RF_Engineer
【LoRaWAN】Ra-08/08H系列 2643 11 2023-8-17 19:54:11
Hello All,
This is a question about Ra-08H Development Kit, used with "AT" firmware announced as "+CGMR=release/v1.3.4 LoRaWAN for US915".
MY QUESTION: What is the minimum set of "AT" commands required to be given to a Ra-08H Dev Kit on its serial internface in order to make it transmit one message to a second identical Ra-08H Dev Kit and then to receive one or more messages from the second Dev Kit on the fist Dev Kit?
SITUATION: I have four identical Ra-08H Dev Kits and I would like for the purposes of testing and proof of concept to send one message from the first Dev Kit to the other three Dev Kits.v And I would like them to receive this message. Then, I would like one of these three Dev Kits to send a message to the first Dev Kit and the first Dev Kit to receive it.
I expect that this can be done with "AT" commands described in Ra-08 AT Command document, v0.1.0 from 2022-03-20, which I have and which I read -- but there are many commands in it and they set many different parameters. My question is: what is the minimum list of "AT" commands needed in order to make:
  • The first Dev Kit send a simple message to all (to the other three Dev Kits)?
  • The first Dev Kit to receive one or more messages from one of the other three Dev Kits?
I want to avoid setting many uneccessary parameters and executing many uneccessary "AT" commands. I would like to ask for help with what are the absolute neccessary "AT" commands to send and receive a message.
All advice will be greatly appreciated.
This is one of my first posts on this here forum, apologies if I did something not right, thanks for your good humour.
2023-8-17 20:50:38
hey man,you not have any mistake,you are good. this question our Yuanzhang already seen it,him will help you solve,wait a minite
2023-8-17 22:48:07
Many thanks for the prompt reply -- this is indeed great customer service!
Thanks again.
Hi Man , to achieve this function, you need to burn the firmware separately, or you can do secondary development based on our Ra-08 SDK source code.
@yzz199442
2023-8-18 13:40:28
Many thanks for your reply, but have you read my question? Also, have you watched the video,which you linked? None of it is about my question because none of it is about "AT" command set.
I actually had watched the video two days ago -- the video, which you linked, it is one of the top results on YouTube searching for "Ra-08", so it was the first video that I watched -- and it has nothing to do with "AT"commands and nothing to do with my question. It also is not technical -- it is a commercial presentation showing just some pictures and providing no technical information. This is why one YouTube user asked in the comments to the video where to get the project files and the answer to the question on YouTube was a joke: it linked to the User Manual webpage --completely useless and totally the wrong place, because there is  nothing in the User Manual about what was shown on the video. And of course, the video on YouTube is not about my question -- it is not about"AT" commands and not an answer to my question.
2023-8-18 14:09:33
AiThinker-半颗心脏 发表于 2023-8-18 08:05
Hi Man , to achieve this function, you need to burn the firmware separately, or you can do secondary ...
Many thanks for your answer. In your answer you said "... or you can do secondary development based on our Ra-08 SDK source code ". Is this right?
Do you say that in order to send and to receive a simple message the user will need to do secondary development and change the source code of the SDK? Is it not possible to send and receive a simple message with the "AT" commands!?
I think that your answer perhaps was aimed at a different question. My question is what is the minimum list of "AT" commands to send and to receive a message. I do not want or intend to do secondary development and modify the source code of the SDK. Why? Because the "AT" commands have already a command to send and another command to receive messages, I want to use these commands, but it appears that before sending or before receiving a message one needs to set quite a few parameters. My question is about these "AT" commands -- what is the minimum set of "AT" commands that is required in order to send and receive a message.
Do you have a concrete example? Please do not answer in general, please answer my specific question, ideally answer by listing the "AT" commands together with some example parameters and in the correct order that these commands need to be issued to a Ra-08(H) Dev Kit on the serial interface to it.
Once again, many thanks for your response. It was not an answer to my question.
RF_Engineer 发表于 2023-8-18 14:09
Many thanks for your answer. In your answer you said "... or you can do secondary development based ...
Thank you for your advice.
1/ The first Dev Kit send a simple message to all (to the other three Dev Kits)?
2/ The first Dev Kit to receive one or more messages from one of the other three Dev Kits?
All of the above problems can be solved. LoRaWAN protocol stipulates that point-to-point communication is not allowed, so only LoRa private protocol can be followed, and the firmware needs to be updated. Please refer to this link:
http://bbs.ai-thinker.com/forum. ... &extra=page%3D1
Thank you for your advice again.
2023-8-22 00:58:43
@AiThinker-半颗心脏,
Again, many thanks for your response and for the link -- I will take tonight a detailed look at it and post here about any success. The link looks detailed, so I am hoping that it will provide a good answer to my question.
Kind regards,
RF Engineer.
2024-2-8 10:26:08
  • 会员数: 29738 个
  • 话题数: 43250 篇
