12
返回列表 发新帖
2024-8-28 10:47:14
爱笑 发表于 2024-8-28 10:24
这是技术写的!
哪个技术写的,表扬下
2024-8-28 11:18:00
打卡学习
学习学习
2024-9-2 09:24:08
学习打卡
2024-9-5 14:01:21
学习打卡
我使用这个工程进行串口接收测试,hosal_uart_dev_t uart_dev_int = {
    .config = {
        .uart_id = 0,
        .tx_pin = 16, // TXD GPIO
        .rx_pin = 7,  // RXD GPIO
        .cts_pin = 255,
        .rts_pin = 255,
        .baud_rate = 115200,
        .data_width = HOSAL_DATA_WIDTH_8BIT,
        .parity = HOSAL_NO_PARITY,
        .stop_bits = HOSAL_STOP_BITS_1,
        .mode = HOSAL_UART_MODE_POLL,
如果发送更长的数据ATSOCKETSENDasdqwertyuiopzxcvbnm123456789,接收到的__uart_rx_callback : 1
rx num : 0 0x41
__uart_rx_callback : 8
rx num : 0 0x54
rx num : 1 0x53
rx num : 2 0x4f
rx num : 3 0x43
rx num : 4 0x4b
rx num : 5 0x45
rx num : 6 0x54
rx num : 7 0x53
__uart_rx_callback : 32
rx num : 0 0x45
rx num : 1 0x4e
rx num : 2 0x44
rx num : 3 0x61
rx num : 4 0x73
rx num : 5 0x64
rx num : 6 0x71
rx num : 7 0x77
rx num : 8 0x65
rx num : 9 0x72
rx num : 10 0x74
rx num : 11 0x79
rx num : 12 0x75
rx num : 13 0x69
rx num : 14 0x6f
rx num : 15 0x70
rx num : 16 0x7a
rx num : 17 0x78
rx num : 18 0x63
rx num : 19 0x76
rx num : 20 0x62
rx num : 21 0x6e
rx num : 22 0x6d
rx num : 23 0x31
rx num : 24 0x32
rx num : 25 0x33
rx num : 26 0x34
rx num : 27 0x35
rx num : 28 0x36
rx num : 29 0x37
rx num : 30 0x38
rx num : 31 0x39
__uart_rx_callback : 0
blufi demo test 260
缺了很多,这是为什么,三种方式都不能完整接收到我发的一帧数据
static void uart_init(void)
    hosal_uart_init(&uart_dev_int);
    hosal_uart_ioctl(&uart_dev_int, HOSAL_UART_MODE_SET, (void *)HOSAL_UART_MODE_INT);
    hosal_uart_callback_set(&uart_dev_int, HOSAL_UART_RX_CALLBACK,
                            __uart_rx_callback, &uart_dev_int);
    hosal_uart_callback_set(&uart_dev_int, HOSAL_UART_TX_CALLBACK,
                            __uart_tx_callback, &uart_dev_int);
    hosal_uart_ioctl(&uart_dev_int, HOSAL_UART_TX_TRIGGER_ON, NULL);
    // hosal_uart_ioctl(&uart_dev_int, HOSAL_UART_RX_TRIGGER_ON, NULL);
static int __uart_rx_callback(void *p_arg)
    int ret;
    hosal_uart_dev_t *p_dev = (hosal_uart_dev_t *)p_arg;
    ret = hosal_uart_receive(&uart_dev_int, data_buf, sizeof(data_buf));
    printf("__uart_rx_callback : %d\r\n", ret);
    for (int i = 0; i < ret; i++)
        printf("rx num : %d 0x%02x\r\n", i, data_buf);
    return 0;
接收到的数据不完整发送123456789,接收到__uart_rx_callback : 1
rx num : 0 0x31
rx num : 0 0x32
rx num : 1 0x33
rx num : 2 0x34
rx num : 3 0x35
rx num : 4 0x36
rx num : 5 0x37
rx num : 6 0x38
rx num : 7 0x39
2024-10-21 17:57:02
    .config = {
        .uart_id = ...
我让技术给你瞧瞧!
  • 会员数: 30688 个
  • 话题数: 44751 篇
